wagoneer LTD. wont shift into gear from park - JeepForum.com
post #1 of 3 Old 10-22-2009, 12:09 AM Thread Starter
Cefalak
1986 Jeep wagoneer LTD. V6 Carb. automatic
The jeep engine runs and the shift lever will slide threw the gears nice, when put in reverse the lights come on ext. but will not move. (forward or back)
It sounds like the linkage on the tranny that turns and clicks into gear(s) is slipping maybe??
please help!!! thank u thank u cheers
Cefalak is offline
post #2 of 3 Old 10-22-2009, 02:15 AM
keepishop
1989 XJ Cherokee
Have you checked the transmission fluid level yet? How many miles are on it?
Current: Black 89 limited, dakota bastard pack, zj coils, 1.5" lift, open cooling swap,
Rest in Pieces: Red 1990 cherokee dana30/8.25 - v8 zj coils & s10 bastard pack 2.5" lift - 31x10.5r15 tires - v8 zj tierod
Originally Posted by talentjeep View Post
Bleed or Quit.
jf irc @ irc.freenode.net #jeepforum
keepishop is offline
post #3 of 3 Old 01-25-2010, 11:10 PM Thread Starter
Cefalak
yeah the fuild is up to level and clean, I took apart the shifting linkage underneath the lever, underneath the jeep next to the trans. and tightened it up but it still seems to slide on the pin on the trans.
But im not sure if it should slide on the pin or not?
Was thinking of welding it soild just to see if it would do anything lol
I also heard that vaccum off the engine could affect the shifting on the auto trans.? anyone know if this is true and maybe a simple way to test it?
The wagoneer LTD is a dusty mint POS ride we were just gonna duke at the river, its hardly worth my time really so if anyone up in the fraser valley (Canada) wants it for a $100 ill go that route too haha
or maybe youll see at pick a part.
Cefalak is offline
Cold transmission wont shift out of 1st gear sAe23 XJ Cherokee Technical Forum 38 07-01-2013 06:51 PM
1991 transmission wont shift in proper gear corbin9191 XJ Cherokee Technical Forum 6 01-27-2009 11:11 AM
90 XJ - Won't Shift out of park when key is on Overdrive XJ Cherokee Technical Forum 5 03-04-2007 05:58 PM
cannot shift out of park 88wagon XJ Cherokee Technical Forum 5 08-22-2006 09:52 PM
Cherokee AT: Hard to Shift Out Of Park Sykes XJ Cherokee Technical Forum 4 07-13-2003 11:13 PM
