Quantcast vote for the July 2005 C.O.M. **Modified Class** here - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > vote for the July 2005 C.O.M. **Modified Class** here
View Poll Results: vote for the July 2005 Cherokee of the Month **Modified Class**
wil badger 56 51.38%
HeavyMetal 7 6.42%
atfrith 9 8.26%
Dannyboy18 15 13.76%
AUTOPERSONALITY 2 1.83%
extankerguy 7 6.42%
cruzmyxj 13 11.93%
Voters: 109. You may not vote on this poll
Old 06-25-2005, 03:12 AM   #1
EricsXJ
The Post man
EricsXJ's Avatar
OK, everyone that didn't make it in, was because you submitted pics over the size limit, many of which are WAY TOO BIG. Rules
Entry #1
wil badger
the jeep is a 95 plain jain Cherokee.has new Jasper reman 4.0 motor,AW4 auto,231 with Advanced Adapters SYE,Rusty's 8" long arm lift with SkyJacker 8" coils up front.Rigidco front bumper and home brew rear bumper with tire swing.sits on 36" IROKs on Allied StoneCrusher rims.the rears are fullsize dana 44 and rear dana 60.both are locked with Detroits and 5.13 gears with alloy axles.
this is a pic of it right after the fullsize axle swap.i don't have to many since the swap.but there are alot of other pictures to pick from before the swap
Entry #2
HeavyMetal
1997 Cherokee SE 4.0
Rusty's 3" AAL Lift
31x10.5 BFG All-Terrains K/O
Rusty's K&N Airtube Setup
C4X4 Front Tow Hooks
Rear Class III Hidden Hitch
Rusty's Engine Tranny/TCase Skids
Skyjacker Sway Bar Discos
"Walmart Light Mod" w/ Hella 500s
CB Setup and whatnot
Surco Safari Roof Rack 45X50
Entry #3
atfrith
Rusty's 3" coils up front
Rubicon Express 3.5" full leaf packs in the rear
31x10.50 Dunlop Mud Rovers on 15x8 Cragar Soft 8's
Dynomax Cat-back exhaust
K&N 6x9 Air Filter and Rust's Intake Tube
JKS quick discos, rear sway bar tossed
Cobra CB with PA speaker setup
4.0L straight 6, AW 4 tranny
Entry #4
Dannyboy18
- Specs:
Model & Year: 1999 Sport
Engine: 4.0L
Driveline: NP231, Auto Tranny, HP30 (front) + C8.25 (rear)
---Modifications---
Engine: K&N Drop-in filter
Suspension: Rubicon Express Super Ride 3.5" kit with full leaf packs; OME shocks; Teraflex quick disconnects; Teraflex adjustable track bar; removed rear swaybar
Driveline: RE SYE kit; Tom Woods custom CV driveshafts
Wheels: American Racing "Baja" 15x8 (polished alloy)
Tires: 31x10.50 ProComp M/Ts
Misc: C4x4 front tow hooks; Alpine CDE-9845 HU + (4) Pioneer 5.25" 3way speakers.
EricsXJ is offline   Reply With Quote
Old 06-25-2005, 03:14 AM   #2
EricsXJ
The Post man
EricsXJ's Avatar
Entry #5
AUTOPERSONALITY
1999 JEEP CHEROKEE SPORT
BORLA HEADER
SAFARI SNORKEL
CUSTOM MADE ROOF RACK.
6 HELLA SPOTLIGHTS (FOUR AT THE FRONT OF THE ROOF RACK, 2 AT THE REAR)
2 HELLA FOGLAMPS ON BUMPER
4" LIFT KIT.
SKYJACKER SHOCKS.
SEPARATE TRANSMISSION OIL COOLER
600WATT AMP WITH 12" SUBWOOFER 4 MIDRANGE AND 2 TWEETERS
30.5 INTERCO THORNBIRD TIRES.
ALL FLOOR AND DASH PANEL HOLES FILED WITH FOAM.
Entry #6
extankerguy
1987 Jeep XJ Wagoneer
4.0 litre 6 cylinder w/336,000 miles
AW4 Transmission
NP242 Transfer Case
31x10.50 BFG Mud Terrains
TJ Canyon Wheels
4.5" lift
YJ brake lines
adjustable lower control arms
adjustable upper control arms
ARB air compressor
ARB front locker
ARB rear locker
Dana 30 front axle w/4.56 gears
Dana 44 rear axle w/4.56 gears
K&N open element air filter
Flowmaster 50 series muffler
front receiver hitch
rear receiver hitch
receiver shackle mounts
30,000 lb recovery strap
Hi-lift jack
Panasonic CD/MP3 player
Uniden CB w/weather radio
fire extinguisher
first aid kit
some rock rash
And the all important Trail Rated Badge!
Entry #7
cruzmyxj
97 Jeep Cherokee Country.
98 4.0L 242 inline six. Rebuilt cylinder head and rering with about 500 miles on it since.
AW4 fluid and filter change less than 10,000 ago with Lucus oil.
RE hack and tap with custom drive shaft.
18 inch stainless steel rear brake line. Front brake line drop brackets.
Front brake bolts custom conversion to 9/16 bolts after repeated breakage of stock hardware.
33x12.50r15 Mickey Thompson Baja Claws. Black Steel RockCrawlers 15x8.
Skid Row Automotive gas tank skid.
Skid Row Automotive LCA Skid plates, not in pics.
Roc/trail lights.
DynoMax cat back exhaust. Random Technologys high flow cat. Borla header.
Custom/JKS upper rear shock mounts.
Skyjacker rear lift shackle. Skyjacker rear 3" lift soft ride full leaf packs.
Safari Guard Taillight cages. AVS tailight black outs.
5 percent widow tint on all rear, 20 percent on front.
Factory sunroof? Maybe DEO.
Second front drive shaft, don't ask.
RE control arm relocation brackets and braces.
Skyjacker LCA, stock upper.
Skyjacker softride 3" front coil springs.
JKS ACOS.
Terraflex swaybar discos.
Stock TB with Skyjacker relocation bracket, this if fixing to be changed.
Skyjacker drop pitman arm.
Skyjacker Nittro 8000's on all four corners.
Skyjacker hydro 5000 steering stabalizer.
True Blue headlight conversion.
ARB Bullbar front bumper.
Mile Marker 8000.
Hella Black Majic Ralley 5000's.
Airmax sprial flow intake system w/ K&N.
Helix power tower throttle body spacer.
Three row copper radiator.
Seperate, I can't remember what type, tranny cooler.
Custom, I ain't gonna tell you about it kill switch.
Sony Xplode head unit. Sony Xplode 6 1/2 two ways in the door. Sony 8" stealth subs in the rear cargo panels.
First Aid kit in whats left of the rear cubby hole.
Fire extinsher on the pass. side of the tranny tunnel.
Cobra 40 channel cb. 4' firestick antenna on custom mount.
Trail rated badge.
NP 231.
Chrysler 8.25 with 29 splines. Detroit lunch box locker in rear.
Dana 30 HP. Open spicer 297.
Blacked out front side markers, and ARB turnsignals.
Mustang oil filter, synthetic blend oil with full synthetic Lucus.
Lucus oil power steering fluid.
Power steering box brace.
Bushwacker cut out fender flares for pre 97 Cherokee.
EXTENSIVE fender trimming.
Sawzalled ARB Bullbar for clearance.
Incase you are not familer with the country package, power windows, locks, mirrors, sunroof. Keyless intry. Leather steering wheel. Nice wood grain plastic dash and door inserts. Full gages with tac. Muddied up carpet everywere. Cloth stained seats. rear defrost and wiper. I don't know what all is country pack. and what isn't.
5 aluminium snow flake rims which will soon get some 31 at's for winter.
Total lift measured to factory fender flares before cutting and springs seattling was 6 front 6.5 rear.
Seattled to about 5 and 5 by my estimation.
Lots of routine parts.
All mods performed by owner, that's me.
Old 06-25-2005, 04:11 AM   #3
silverxj2001
anthony you got my vote buddy
ive put a good amount of blood, knuckle skin, and sweat into your rig and i hope you win
2001 2-door XJ prerunner
6.5" RE
33x10.5" BFG A/T KO
15x8" rockcrawlers w/3.75" bs
hannemann 6" bulge flat top fiberglass fenders
bilstein 11" travel 5150's
RE XD trackbar / frame mount
RE adj. LCA/UCA's
beard triple thick limit straps
rusty's steering box brace
truckfarm pre-runner bumper
intake / exhaust
procomp lighting
system... yada yada yada
[URL=http://www.cardomain.com/memberpage/437678/1]PICS OF MY XJ[/URL]
silverxj2001 is offline   Reply With Quote
Old 06-25-2005, 08:45 AM   #4
Dannyboy18
I wish I had some offroad pictures for my entry...
Oh well, next month...
--Dan.
1999 Cherokee Sport - Black; 4.0L AW4, NP231 w/ D30 and 8.25C.
RE 3.5" Super Ride w/ full packs (4* shims) + OME shocks + RE SYE w/ Tom Woods CV
Yukon 4.10s
AR Baja Alloy Wheels - 15x8 + Bridgestone Dueler Revo A/Ts - 31x10.50x15
TeraFlex Adj. Trackbar + TeraFlex Quick Disconnects & WARN T-case skid
Dannyboy18 is offline   Reply With Quote
Old 06-25-2005, 11:37 AM   #5
HeavyMetal
Forum God
HeavyMetal's Avatar
1997 XJ Cherokee
now just to pray i dont get owned
Though I wheel through the valley of the shadow of death,
I will fear no evil: For thou lockers are with me;
Thy lift and thy tires, they comfort me.
Thou preparest a spotter before me in the presence of mine obstacles;
HeavyMetal is offline   Reply With Quote
Old 06-25-2005, 06:50 PM   #6
extankerguy
1987 XJ Cherokee
1987 XJ Wagoneer
4.0 - NP242 - D44s - Detroit front / ARB rear - 5.38s - 36" TSL/SX - 4.5" lift
extankerguy is offline   Reply With Quote
Old 06-25-2005, 06:57 PM   #7
Silver TeeJay
Dannyboy: You got my vote - after all I modeled mine after yours!
[B][COLOR="Silver"]2005 Jeep TJ "RME" - Bright Silver Metalllic - 4.0 Auto
2" BDS Coil Spacers / BDS Steering Stabilizer / BDS 5500 CAV Shocks / JKS 1.25" BL / JKS 1" BMML / Dana 44 / 3.73 Gears / Custom Rock Sliders / 32x11.50 BFG KO's / 15x8 AR Diamond Backs
[B][I][U][/COLOR][/B]
[COLOR="Silver"][SIZE="2"][COLOR="Silver"]Proud member of the KC Jeep Club![/COLOR][/U][/I][/B][/SIZE][/COLOR]
Silver TeeJay is offline   Reply With Quote
Old 06-25-2005, 07:11 PM   #8
HeavyMetal
Forum God
HeavyMetal's Avatar
1997 XJ Cherokee
soemthing tells me badger is running away with this one
Old 06-25-2005, 08:46 PM   #9
firefighter1c57
SPACE FOR RENT
firefighter1c57's Avatar
As he should. His suspension is what I dream of at night.
piks
I bring NOTHING to the table.
firefighter1c57 is offline   Reply With Quote
Old 06-25-2005, 09:41 PM   #10
Blake
Redefining body roll
Blake's Avatar
I'm sorry, but the full-widths get my vote.
2005 G35 Sedan
Sport Package | Mostly Stock
1999.5 Ford F250
6.8l V10 l Auto l 4WD l 4" Spring Lift | 4.30 Gears | 35" Treadwright MT/R's
1987 Mercedes 300D Turbo
Stock | European Headlight Conversion!!1!
Blake is offline   Reply With Quote
Old 06-26-2005, 12:45 AM   #11
firefighter1c57
SPACE FOR RENT
Whoooo so far I am the first loser. I almost voted for Badger's rig too. It is awesome, but I am just to arrogant.
piks
Old 06-28-2005, 08:55 PM   #12
JEEPZZ
You got my vote John (aka Wil Badger)!
I've seen this Jeep in action first hand and I can say that his suspension is
[FONT=Trebuchet MS][size=1]97XJ RENEGADE
JEEPZZ is offline   Reply With Quote
Old 06-28-2005, 11:08 PM   #13
jeepkid8037
Badger got my vote, i am hoping to be doing either a hp44/9" or hp44/d60 swap sometime in the near future, and i hope it turns out as nice as his dose. Nice rig!
[B][COLOR=DarkRed][COLOR=DarkRed][B]93 xj 211,000 miles
rusty's 4.5" lift
aa sye
tw cv ds
ford 8.8 w/ 4.10 gears and an aussie locker
4.10 gears front
15x8 rockcrawlers w/ 3.75 bs
33x12.5 radial tsl's
no swaybars[/B][/COLOR]
Got her back![/COLOR][/B]
[COLOR=Yellow]http://www.freeiPods.com/?r=17745586 free ipod[/COLOR]
[COLOR=Yellow]http://www.geocities.com/campo4x4/Campolindo_4x4club.html[/COLOR]
jeepkid8037 is offline   Reply With Quote
Old 07-01-2005, 04:19 AM   #14
wil badger
thanks guys .as you all know they are never finished and always need something new, so keep building.
here is a little clip from 6-26-05 while i was on the east coast playing in Paragon
small flexing vid
you might need DivX codec or DivX player to view it.
DivX player
One Built XJ
wil badger is offline   Reply With Quote
Glock Forum
