vote for the JeepForum 2007 Cherokee of the Year **Modified Class**
| Official Chassis Saver Rust Preventive Truck & Auto Un | TJ 5.25" Speaker Adapters - NalinMFG | SALE -- Yukon Gear Free Spin Hub Conversion Kit - Dana 30 |
| View Poll Results: vote for the JeepForum 2007 Cherokee of the Year **Modified Class** | |||
| Grand Fan 4eva |
9 | 5.56% |
| RandysCJ (MJ) |
7 | 4.32% |
| ktmracer419 |
9 | 5.56% |
| gregmondro |
4 | 2.47% |
| HeavyMetal |
34 | 20.99% |
| LEAD_NOT_FOLLOW |
17 | 10.49% |
| Cruzin Illusion |
67 | 41.36% |
| XJ Jeremy |
9 | 5.56% |
| TheRifleman |
0 | 0% |
| Shmoken875 |
3 | 1.85% |
| XJ_Jeeper01 |
3 | 1.85% |
| Voters: 162. You may not vote on this poll | |||
#1 | |
The Post man
This is another contest for us to choose which XJ should have the honors of being JeepForum's 2007 Cherokee of the Year in both Stocker and Modified classes. The contestants are the winners of the COM from each month in 2007.
Along with having the prestigious title of Cherokee of the Year, the winners will also recieve a free copy of my book High-Performance Jeep Cherokee XJ Builder's Guide. ![]() Here are the choices from the Modified Class: January Grand Fan 4eva *'97 Cherokee Sport, 4-door, 130,xxx miles *Rusty's 3" full leaf kit *Rocky Road 2" BB*Pro-comp Chromoly Series LCA's*RE Hack n' Tap*Rusty's Steering Stabilizer *33x12.50x15 Trxus M/T's *15x8 Cragar Soft 8's *5-speed, NP231, Chr. 8.25 *Homemade disco's & extensions*Wally World Baja Lights *100w KC HiLites(roof rack)*Cyber White Fogs*Rear Facing Fogs(roof rack)*Thule M.O.A.B. Basket *Magnaflow Cat(2.5")*Flowmaster Super 40(2.5")*Rusty's 2.5" Tailpipe*Custom ZJ 5.2L Airbox*Midland CB*JCR Stg 3 Bumper W/ Hoop *Trimmed Fenders*Air Horn*Custom Decals*Custom Rock Shift Knob*Custom Headlight Stone Guards* Custom Painted Center Console*Wix Over-size Oil Filter*Custom 3/16" "Jeep" Rock Rails*Doorless Mod*750/1500watt a/c Power Inverter*Manual Aux. Fan Over-ride*Clutch Saftey Switch Manual Over-ride*Custom "Jeep" Tail light*Way-Finder Navigation System*Optima Red Top(34/78)*Red 4ft Firestik II*Fire Extinguisher*Mopar Gas Tank and Front Skids*2" Reciever w/ Shackle*4.56 gears*Assuie Locker(front) ![]() ![]() February RandysCJ 1990 Comanche Eliminator Engine: 4.0 (stock) Imco Pro Series exhaust Drivetrain: AX-15 NP231 J-10 Axles D44 front, 4.88, lockright AMC20 rear, 4.88, Powertrax No-Slip Suspension & Steering: Front leaf conversion using 4" Pro Comp YJ Leaves Spring over rear with 2" fullsize Chevy AAL's Crossover steering using KOZ Offroad high steer arm Wheels and Tires: 15x10 Eagle Alloys 37x13.50r15 Baja Claw radials Recovery: JCROffroad front bumper Homemade rear bumper, d-ring shackle receiver Misc: rock lights Sony CD player Pioneer bass tube TJ flares ![]() ![]() March No winner. April Ktmracer419 Base: 91 xj laredo 4.0L aw4 np231 Front axle: fullsize dana44 5:38 yukon gears detroit locked 30 spline moser alloys warn premium locking hubs spicer 5-760x u-joints Rear axle: fullsize dana44 5:38 yukon gears ox locked 33 spline moser alloys. Suspension: custom radius arm/longarm about 5" of lift tnt customs trackbar with bracket. re 4.5" rear leaves (actual 3.5") 1.5" rock road outfitters shackles dpg adjustable rear bumpstops hockey puck front bumpstops edelbrock ias shocks Tires/wheels: 37" x 13" super swamper bogger tsl's on 15x10" black steelies with 4.0" backspacing. Misc: dpg belly skid factory jensen "Accusound" 6 speaker system with a $5 yard sale cd player. recovery junk. doorless mod ![]() ![]()
#2 |
The Post man
May
gregmondro 1999 Jeep Cherokee Sport NP231, SYE, 4.56's, Rear D44 w/ Detroit SoftLocker, 35x12.5 BFG A/Ts, RE 5.5" XD Lift, Skidrow TC Skid, Off-Road Technology Rear Bumper + Carrier, Rigidco Front Winch Bumper + Steering Box Plate, Milemarker 8000 Winch, Rock Sliders, HD Currie Steering, Control Arm Skids, Optima Red Top and a few other goodies... ![]() ![]() June HeavyMetal 1997 XJ 4.5" RE 6130 Springs TNT Y-Link Long Arms D30/D44 w/4.56 gears and PowerTrax No-Slip rear locker Custom 1-Ton Steering Bilstein 5150 Front Reservoir Shocks RE Monotube Rear Shocks 35x12.5 Cooper Discoverer STTs on Ravine Wheels Custom Recovery Front Bumper RockLizardFab Gas Tank Skid TNT Belly Pan Skid JCR Stage 2 Sliders PMW Side Armor Plate TNT Trackbar System Hella Rallye 4000s(2) ![]() ![]() July LEAD_NOT_FOLLOW 1989 Cherokee Laredo Motor Golen 4.6L Stroker 9:1 Compression Ratio. Redline right under 6K. Block: Thermally cleaned and Stainless Steel Shot. Inspected by MPI process. Decked, bored, honed with torque-plates and pressure washed. Clevite cam bearings and pioneer brass freeze plugs installed. Crank: Peformance ground 4.2L crankshaft, micro polished and oil holes chamfered. Rods: Jeep steel rods, shot peened for strength, resized with new performance rod bolts. Pistons: Speed-Pro hypereutectic. Rings: Speed Pro Plasma-Moly. Bearings: Clevite Main and Rod Bearings. Core Plugs: Brass Pioneer core plugs. Lifters: Comp Cams Hydraulic. Pushrods: Comp Cams. Rocker Arms: Comp Cams. Timing Set: Dynagear Performance. Cams: Comp Cams. (duration) - Intake: 218˚@ .050˚ Exhaust: 226˚@ .050˚ (lift) - Intake: .493˚ Exhaust: .512˚ (seperation) - 111˚ Oil Delivery: Melling high volume pump, pickup tube and HD Drive Gasket Set: Fel-Pro Performance Head Bolts: SBI Performance Head: '95 HO Head. Combustion Chamber: 62cc - Intake Runner: 155 cc. Three angle valve job, bowl ported, valves back cut, new guides etc. Exhaust: Custom Header/Downpipe/Exhuast Engine Management: Motec Cooling: Hesco High Flow Waterpump, CSF 3 Core Radiator, Hesco High-Flow T-stat Housing, BRX Hoses, Mr. Gasket High-Performance T-stat. I'm at aprox 290HP @ 5000rpm and 330ft/lbs @ 4000rpm. Kenne Bell Supercharger in the works... Drivetrain/Axels AW4 w/switch shift mod NP231 1" TC Drop Dana 30 Front w/Detroit Locker Dana 44 Rear Lift/Tires 5” Hybrid Lift RE Superflex Adjustable Upper and Lower Control Arms RE 3.5” Rear Leafs RE 1.5” Boomerang Rear Shackles RC Front Springs OME Shocks RE Gen. 2 Quick Disco’s Motion Offroad Tie Rod w/Flip Kit 35” Maxxis Bighorns 15” Crager Streetlocks Exterior Motion Offroad Rock Crawler Front Bumper Custom Rock Rails LaBarron Hood Vents ARB Safari Snorkel Rear Quarter Guards Metal Taillights w/Led’s Removed Flares Bedlined Rockers Con-Fer Roof Rack Removable Doors Yakima Powederhound Ski/Board Holder IPF Front Headlights 6 Fog lights (2 on bumper, 4 on rack) Recovery Custom 4X4 Tow Hooks 48" Hi-Lift Jack Axe/Shovel Rear Hitch Gas Tank Skid DPG Belly Skid Motion Offroad C02 Airtank 30ft Strap w/D-rings Interior Eagle Journey GPS w/6" screen Cobra WX 40Chn. CB w/4ft Firestick Beartracker SAR Radio/Scanner Dell Laptop w/Custom Laptop Mount Alpine CD Headunit 800watt Amp w/2 12" Kenwood Subs Custom 7 switch panel Whellen Dash Strobes Whellen Rear Strobe Bar Whellen Corner Strobes (use the vehicle for SAR) ![]() August Cruzin Illusion 1987 Jeep Cherokee Pioneer Drivetrain: 4.0 Liter AW4 Transmission NP242 Transfer Case Tom Wood’s SYE Tom Wood’s Drive Shafts Custom 2.5” Exhaust Cruzin Illusion Custom’s Intake K&N Air Filter MAC’s Radiator Close System Aluminum Coolant Bottle Axles: Front: High Pinion Dana 44 Alloy USA Custom Length Chromoly Inner Shafts Alloy USA Chromoly Outer Shafts Yukon Super U-Joints 5.13 Yukon Reverse Cut Gears ARB Locker Cruzin Illusion Custom’s LCA Skids TNT Custom’s High Pinion Dana 44 Truss Conversion TNT Custom’s Truss Riddler Chromoly Differential Cover Above Axle Track Bar Conversion Rear: Dana 44 Superior 33 Splined Shafts 5.13 Yukon Gears Gears 33 Splined Detroit Locker Cruzin Illusion Custom’s 8.8 Brake Conversion Crane Differential Cover Rear Truss Suspension: Rubicon Express 7.5” Extreme Duty Coils JKS ACOS Spacers Cruzin Illusion Custom’s Extended Bump Stops JKS Bar Pin Eliminators TNT Customs Above Axle Track Bar Bracket for Axle Side TNT Customs Frame Side Track Bar Bracket TNT Customs Track Bar with RE Superflex Joints on both ends TNT Customs XD Bellypan TNT Customs Y-Link Radius Arms Triangulated 4-Link Rear Suspension Fox Shox Coil-Overs Steering: Cruzin Illusion Custom’s High Steer Conversion C-Rok Sleeved Inner Steering Brace PSC 8” Hydraulic Ram PSC Power Steering Pump with Remote Reservoir PSC Steering Gearbox Parts Mike Parts HD High Steer Arms Tires and Wheels: Cruzin Illusion Customs Built 15x9 Beadlocks 35”x13.5”x15” BFG Krawlers Interior: Cruzin Illusion Custom’s 10 Point Roll Cage MasterCraft Rubicon Seats MasterCraft 5 Point Racing Harnesses for Front Seats MasterCraft 4 Point Racing Harnesses for Rear Seat 10lb. CO2 Air Tank Cruzin Illusion Customs Manual 4 Low 2nd Gear Switch Modification Exterior: Rigidco Front Bumper with Boxed in Frame Supports Rigidco Rear Bumper with Tire Carrier Cruzin Illusion Customs Rock Sliders with Tube Extensions Warn 8000lb. Winch with Synthetic Rope Cruzin Illusion Custom’s Door Pin Off Conversion Cruzin Illusion Custom’s Tube Fenders Front with 3/16th inch fender plating Cruzin Illusion Custom’s Tube Fenders with 3/16th inch quarter guards with built in Tail Light Housings with LED lights Cruzin Illusion Custom’s Frame Rail Reinforcements Rear Quarter Panels Cut and Folded Modification Cruzin Illusion Custom's Tube Doors Cruzin Illusion Custom’s CJ Round Headlight Grille ![]() ![]() Last edited by EricsXJ; 12-22-2007 at 11:32 PM.. |
#3 |
The Post man
September
XJ Jeremy 96 XJ Sport 5spd 8"Skyjacker Rock Ready kit W/ 2" spacers Ford Explorer 8.8" rear end w/ disk brakes Detroit Locker in rear 4.56 gears Tom Woods drive shaft Advanced Adapters SYE Warn winch bumper M8000 winch D30 diff cover T-case skid plate Hella fog lights driving lights H4 head light conversion Kargomaster roof rack W/ Hi-Lift and shovel Alpine and Garmin nav M.T. 15x10 Classic Locks M.T. 35/12.50/15 Claws Power Slot ft and rear rotors Hawk pads ft and rear Rouch Racing 8.8" diff cover Center Force clutch K&N FIPK Jet stage II chip and 180deg t-stat MSD 6AL ignition and wires 160amp alt 4, 800CCA batt's Sound system, it changes all the time (I own a stereo shop). High flow water pump 3 core radiator KC back up lights U-Turn steering Bushwacker cut-outs CB Auto Meter gauges Viper 2-way alarm w/ remote start Power windws and locks Rock sliders ![]() ![]() October TheRifleman 1989 Jeep Cherokee XJ Beaten, Bruised and Broken Body and Bumpers Custom Cut Fenders Rubicon Express 6025 Super Ride with JKS quick Discos Crystler 8.25 Rear 4:56 Gears, Powertrax No-Slip Locker and Ruff Stuff Diff Guard Dana 30 Front 4:56 Gears Aussie Locker and Ruff Stuff Diff Guard 33x12.50 Mickey Thompson MTZ on 15x8 black Steelies Rebuilt NP231 Transfercase with RE SYE and RE driveshaft C4x4 Tow Hooks and Rear Hidden Hitch Doorless Mod Skid Row Transfercase Skid Transmission Cooler ![]() ![]() November Shmoken875 1998 XJ sport 140k miles young Suspension: -6" Skyjacker coils -1.5" Rustys shackles, and control arms -4.5" RE leafs -Rock Krawler shocks and heavy duty heim trackbar Tires/Wheels: -35x12.50x15 BFG Muds on 15x8 Cragars Driveline: -Stock 4.0, aux cooled AW4, flowmaster 50 series -Hack n tapped 231 with XJ front shaft -29 spline 8.25 rear, 4.56 Yukons, Powertrax locker, Spidertrax 4.5 to 5.5 adapters, drilled out yoke (u-bolts) -Waggy Dana 44 front with Ford hub conversion, Warn Premium hubs, Alloy USA chromoly shafts and Yukon superjoints, 4.56 Yukons, Lock-Right, shortened stock front shaft Armor/Recovery: -JCR front bumper with tie-ins/ rear hitch -Rustys T-case skid plate -S&W Racecars roll cage (curently 6 pt, will add more later) -Sheetmetal (second drivers door), rockers, and "frame rails" all provide armor enough lol -Home fab trackbar brace -Band-aid ![]() ![]() December XJ_Jeeper01 2001 XJ Sport Suspension: -RE 3.5" Coils with 1" spacers -RE 3.5" Leaves with 1.75" Shackle -Custom Crossover Steering and Trackbar -Rock Krawler 3-link Driveline: -4.0 with Airaid Intake and Flowmaster 40 -AW4 -NP231 with AA SYE and Custom Driveshaft -Waggy D44 Front with Lockright, Warn Locking Hubs and 4.88's -Rear Toyota 8" with factory E-Locker and 4.88's Tires/Wheels: 36x13.50 Bias IROKS on 15x8 Cragar Soft 8's Armor: Front and Rear Custom 4x4 Bumpers ![]() ![]() |
#4 |
Cruzin Ill... gets my vote
tube fenders ftw, along with all the other great fab work |
#5 |
Me too. His rig is just bad ***.
1993 2 door XJ Sport 4.0 5" DPG Coils with 3/4" spacer 4.5" Rough Country Leafs with 1" TNT boomerang lift shackle. TNT Longarms with Bellypan TNT Frame Rail Stiffenerz DPG Gas Tank Skid D30 Aussie locked with Yukon chromollys shafts 4.88s D44 33 spline detroit with Moser chromollys shafts 4.88s Teraflex SYE with Tom Woods custom DS 36x13.50 Iroks on 15x10 Pro Comp Rock Crawlers with Custom beadlocks. |
#6 |
Location: school - Campbellsville, KY; home - Oviedo, FL
cruzin's rig is pretty sweet, but I went w/ Jeeper01's rig....
All of them are badass, though, and I wouldn't mind having any one of them... ![]()
David White 95 XJ - Jacked up and abused White 98 XJ - Stock and babied |
#7 |
Round Eyed XJ
Thanks for the great comments!!! I worked very hard to get the Cherokee to be where it is and appreciate the kind words.
CRUZIN ILLUSION BUILT NOT BOUGHT By Cruzin Illusion Customs View the Cruzin Illusion Rig here: View Cruzin Illusion's Rig (OlllllllllllllO) Rock Frog CIC's Build Threads: XJ Bolt on Tube Fenders / XJ-8 Grille (Round Headlight Grille) / THOR 4x4 Quarter Guard Install / XJ Custom Bumper with Swing Down TIre Carrier / Custom Width HP44 Build and Tech /Cruzin Illusions XJ Roll Cage Pics / Cruzin Illusion Tube Door Build |
#8 |
Haha, Yeah HeavyMetal...
2000 Jeep Cherokee. 4.5', Long arms, Bumpers front and rear, Winch. 1992 Toyota Paseo DD 35+ MPG Colorado Member #89 |
#9 |
The Guru of Nothing
cruzin you rig is just in a league of its own. nice work
-Kyle
North Bay, CA Jeepers Post Here My Build Thread ~My Write Ups~ It's Not Just a Jeep, It's a Lifestyle
#10 |
Cruzin, your rigs amazing.
#11 |
i wish i had a fab shop or 20k i could put into my jeep :`(
big lift, sick tires, awsome accessories, alot of custom work. my jeep won the war, your honda mows my lawn |
#12 |
had to go with Grand Fan 4eva. Really liking all the custom Jeep, Cherokee, and XJ logo's. Looks pretty sweet.
#13 |
I had to vote for lead not follow... i love white jeeps especially that one. you have a beautiful jeep
1998 Jeep Cherokee Classic ALL WHITE |
#14 |
man, i forgot about C.O.Y... a lot of things have changed since those pics but oh well, i still don't think it would matter ha ha. nice rigs guys
TORQUE... An Underrated Anti-Depressant. '97 Cherokee ~6.5" / 33 trxus / RK 3-link '91 Comanche stock/4.10's/ 31's |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
