Voltage Regulator? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ Cherokee Technical Forum > Voltage Regulator?
Smittybilt Hard Tops @ Oconee Off-Road! 706-534-9955XHD Heavy-Duty Hood Latches for JK and TJ available at OcoFS: Jeep Fog Light LED Bulbs! Several Brightness Options!
Unread 09-30-2005, 01:33 PM   #1
kernalklink
1995 XJ Cherokee
Voltage Regulator?
I had an issue yesterday driving down the road: My check engine light came on and my battery gauge was clear down by 9 volts. I realize that gauge is an overall output gauge not just a battery, so i didnt make it too far and i was stuck on the side of the road. I went and got a new alternator and a jumpstart and viola the jeep was running again, but the gauge was still around the 9 volt range, i made it about another mile and then back to the shoulder for me. So i went and got a new battery assuming that my battery must have a bad cell or something that wont take a charge. again the gauge was sitting around the 9 volt range so i wheeled to the closest town 2 miles or so and removed the negative cable from the battery and dead was the jeep. I know the cherokees have a external from the alternator, voltage regulator.
Has anyone ever had to change one of these and what was the work like? How much might it cost?
Casey
95 Cherokee Sport 4.0
83atc 110 nestled neatly in the back!
kernalklink is offline   Reply With Quote
Unread 09-30-2005, 01:43 PM   #2
Matt Gertsch
www.lp.org
Matt Gertsch's Avatar
Sounds to me like a cooked battery.
Derpy Hooves for President in 2012
Matt Gertsch is offline   Reply With Quote
Unread 09-30-2005, 01:55 PM   #3
kernalklink
1995 XJ Cherokee
although i did just buy a brand new battery! and have had it hooked up for about 4 minutes.... Also when i unhooked the battery the jeep died? I really doubt it is the battery
95 Cherokee Sport 4.0 White
04 Grand Cherokee 4.0 White
Supports SSSM
Unread 09-30-2005, 03:25 PM   #4
cmotsvt
The jeep should die when the battery is disconnected, the computer needs power to run. The voltage regulator is internal to the alternator and is probably nopt the problem. Remove the alternator and have it tested tested at the parts store
cmotsvt is offline   Reply With Quote
Unread 09-30-2005, 04:38 PM   #5
TheNerd
...I believe that if the engine is running (and the alternator is good and providing charge) you can remove the battery without problems. I have done this before on several different vehicles, admitedly though, not the Jeep.
-2001 XJ Limited, 4.0L, NP231 w/ SYE, AW4, 4.5" Lift, 32" tires, 4.56's
-1987 XJ Pioneer, 4.0L, NP231 w/ SYE, NV3550, 4.5" lift, 4.10's, D44 rear
TheNerd is offline   Reply With Quote
Unread 09-30-2005, 07:20 PM   #6
cmotsvt
I thought the jeep would die without the battery, I may be wrong.
Unread 09-30-2005, 07:28 PM   #7
oldmanscherokee
1992 XJ Cherokee
the volt gauge runs off of battery voltage. if the battery voltage drops to nine then there is a problem with the charging system. the battery gauge would only drop that low if it was not recieving enough amperage to charge it higher. if the alt is in good running order the jeep will stay running when you disconect the batt if its already running. if when you disconect it it slowly dies out then your alt is not charging. since you got a new alt already and the voltage reg is internal in the alt you have anothet type of problem. the amperage is not getting from the post on the alt to the battery. trace the line and make sure there isnt a fusable link open and make sure the wire itself is connected to all terminals it should be. also check your fuses. i cant remeber if there is a charging fuse in the cherokees. alot of other vehicles have them. next hook a fluke meter up to ground and the term on the back of the alt. get the jeep to run either witha a jump or new batt and make sure the alt is putting out at least 12.5-13 volts. its deffinetly sounds like your charging system isnt getting the power from the alt to your battery. its a very simple system and youve replaced all the main parts already. its going to be somthing else you need to find
full time tech for chevy, part time trail rider
95 Ford Lightning (sold), 09 Caddy CTS-V, 04 Buell Firebolt XB12R w/true flame paint, 00 harley XL chopped, 81 Trans Am, 85 K5 Jimmy 4 inch w/35s, 92 cherokee
10,000 original miles
4.5 inch RC lift
32 11.5 bfg muds
oldmanscherokee is offline   Reply With Quote
Unread 09-30-2005, 08:52 PM   #8
opticalwaveguy
It's not your fault but it sounds as if you fell victim to the classic alternator/battery mistake....
First you notice a severe low voltage problem. You change the alternator first. The problem still occurs. You replace the battery second. The problem still exists. Here's a possible explanation:
Bad battery causes failure of a diode in the bridge rectifier in the alternator. After replacing the alternator the battery is still bad and the new bridge diode bites it. You replace the battery and still see a low voltage under running load.
Check the alternator. If it checks out, the likely problem is a system short which most commonly occurs near the starter or coil.
Note to all: if you have concerns about battery/ electrical. Use a multimeter on the battery first. If the battery has less than 10.4 volts with the engine off, don't try to charge it with the alternator. Remove it from the vehicle and deep charge it with a charger. If the voltage of the battery shows 12.2V +/- 15% you should be OK. Start the engine and check the battery voltage with a multimeter again. you should see 14V +/- 1V. If you are showing a value less than before, your alternator should be removed and tested in a shop.
OpticalWaveGuy
www.jeepiki.com - an online resource for Jeep information
Proud To Be A FF/EMT/Police/Military Club Member #2
opticalwaveguy is offline   Reply With Quote
Unread 01-04-2007, 03:31 PM   #9
KEVMOXJ
actually it is an external regulated alternator
KEVMOXJ is offline   Reply With Quote
Unread 01-04-2007, 03:58 PM   #10
bee guz
voltage
i am not sure about, the cherokee, but the YJ has an regulator in the control module, and is not servicable.
Check you application, see if it is in the alt or the ecm. My YJ had the same problem and it was the alternator, but it did get a low charge rate, at times, It was due to bad engine grounds, and a dirty corrosion on the back of the guage.
A long time ago it was a practice to check if the alt was bad by pulling off the battery cable why the engine was running, if the engine died the alt was not charging, but today they caution about doing this on vehicles with computers, youare better of useing a small hand held meter.
Check the alt maxie fuses in the fuse block by the battery, that say charging system....
bee guz is offline   Reply With Quote
Unread 01-04-2007, 04:00 PM   #11
XJH-007
X2
the ECM controls the voltage and is unservicable...aside from replacing it....
Scott-Crawlorado Native
I have an addiction.....
*00' XJ_T-n-T Y-Link/6" RE_OME's_33" KM2's
Tera 4:1 / 4:56's_Elec. Locked D44
**84' CJ7 4"BDS 33's
***02 WJ Overland
XJH-007 is offline   Reply With Quote
Unread 01-04-2007, 06:47 PM   #12
Jeds Sr.
Originally Posted by XJH-007
X2
Correct, the alternator does NOT have a built in voltage regulator. If it turns out that your ECM is bad, don't spend $$$ for a replacement. Add a $15 external voltage regulator. Other auto's, such as Dodge have this same problem, the ECM goes bad and the alternator won't charge. So what do the local mechanics do?? They don't go spend $250 on a new ECM, they add an external voltage regulator.
They are easy to hook up, check this link.
http://www.jeepforum.com/forum/showt...=1#post2950554
Jeds Sr. is offline   Reply With Quote
Unread 09-16-2014, 09:44 AM   #13
wyattx
I had this problem one time, where the voltage gauge was all the way down. when I turned the car off and turned the key back to the on position the gauge went back to where it is supposed to be. I haven't had a problem with it since, that was about two weeks ago. Last night I was driving home and noticed the check gauges light was on and I look at the voltage gauge and noticed that it was all the way UP. When I started to slow down to a stop the gauge went back to normal position. Any ideas?
wyattx is offline   Reply With Quote
