voltage reg problems????? - JeepForum.com
post #1 of 3 Old 09-20-2007, 12:34 PM Thread Starter
lapaz_jeep
Hi,
It's a 97 jeep cherokee 4.0. The voltage meter starts out at 14 when the engine is started, then moves to 16-17 then to 19+ (needle maxed out) and all dash lights come on ABS, check engine, check gages, bla bla.
I changed the Alt. and swaped the battery and still the same.
Any suggestions?
-r
lapaz_jeep is offline
post #2 of 3 Old 09-20-2007, 12:50 PM
csfiend
Originally Posted by lapaz_jeep
Hi,
Any suggestions?
-r
isn't the voltage regulator part of the ECU? or is that only in 96 and older?
csfiend is offline
post #3 of 3 Old 09-20-2007, 01:32 PM
QuadEyedXJ
had the same issue with my 96. Changed the ground from the bat to the frame and cleaned frame where ground wire went all good.
1989 Wagoneer Limited. Gray and Olive Drab, TJ flares, and 31" Mud terrains.
QuadEyedXJ is offline
TPS voltage? 88wrangyj XJ Cherokee Technical Forum 10 09-07-2006 04:59 PM
low voltage williamjonesxj XJ Cherokee Technical Forum 2 06-07-2006 01:09 PM
cluster voltage gauge showing wrong voltage. BackDraft XJ Cherokee Technical Forum 7 03-12-2005 01:44 PM
Low voltage XJCHIEF XJ Cherokee Technical Forum 5 01-02-2004 06:03 PM
voltage jeepercreeper XJ Cherokee Technical Forum 1 02-11-2002 06:53 AM
