Voltage drop when ac compressor runs - JeepForum.com
post #1 of 7 Old 05-20-2006, 01:07 PM Thread Starter
kyleboy7
kyleboy7's Avatar
When I put on my A/C my voltage drops a whole bunch. Is this the alternator going out or something else perhaps?
Gots me a 93 cherokee
kyleboy7 is offline
post #2 of 7 Old 05-20-2006, 01:51 PM
Jeppy
Jeppy's Avatar
if your battery is good it may be a loose (high resistance) ground or positive 12V connection. check them all, if not, look at alt next
2014 White Jeep Cherokee Trailhawk
3.2L
Leather Interior Group, Canyon Brown
Black Hood Decal
MFG build date 10/13
Black Keys all the way up on the stereo:
"Well my Next-Jeep, be nothin' like my Ex-Jeep"
Jeppy is offline
post #3 of 7 Old 05-26-2006, 03:40 AM Thread Starter
kyleboy7
kyleboy7's Avatar
Ok so i did a bit of investigating... Ive discovered that sometimes when i start the engine the belt will squeak... (i think its the belt) and the voltage drops the belt stops sweaking and the voltage goes back up the squeaking is also there when i turn the ac on it will go away if i give it a bit of a rev. The battery is good its about 1yr old optima red top, belt tension appears fine. another note tho is when i turn just the fan on the voltage drops slightly.
Is this a pointing at the alternater or something else?
kyleboy7 is offline
post #4 of 7 Old 05-26-2006, 10:59 AM
dakotus
dakotus's Avatar
I thought this was normal? The AC Compressor uses quite a bit of currrent I thought, enough to make the voltage gage drop for a second. no?
1999 Cherokee Sport
dakotus is offline
post #5 of 7 Old 05-26-2006, 11:50 AM
mylt1
mylt1's Avatar
if your belt is squeeling you may want to tighten the belt. i had a simular problem a while back.
mylt1 is offline
post #6 of 7 Old 05-26-2006, 12:16 PM
MGrobe
Man In Black
MGrobe's Avatar
Might be totally normal. What used to happen with my 98 XJ is that when the clutch on the AC compressor engages, so does the electric fan. And the electric fan would draw enough current to cause my headlights to noticeably dim. The AC compressor clutch would stay engaged for roughly 10 seconds and the fan would keep running during this period.
-Marc-
Sweet Pea 1998 - XJ
For Sale: (4) AR 767-5766 Wheels (used) 15x7, 5x4.5, 4.5BS - for local pickup in the Chicago-area
MGrobe is offline
post #7 of 7 Old 05-26-2006, 12:49 PM
Islandroaddie96
Islandroaddie96's Avatar
Your belt is too loose.
1996 XJ Sport
4.0L I6 HO; AW4; NP242; D30/D35; 3" Homebrew BB; 31" x 10.5" BFG A/T
Six Harbor Freight Lights (el cheapo)
GREEN JEEP CLUB MEMBER #74
Islandroaddie96 is offline
Voltage drop while winching trailreadyjp XJ Cherokee Technical Forum 25 11-30-2009 09:56 AM
battery voltage gauge reads zero..but still starts and runs aircruiser XJ Cherokee Technical Forum 16 02-05-2009 10:44 PM
voltage drop BobbyRobie XJ Cherokee Technical Forum 2 11-12-2007 11:23 PM
voltage going to a/c compressor trailblaze XJ Cherokee Technical Forum 5 07-03-2007 11:38 AM
Voltage Drop j33pn XJ Cherokee Technical Forum 4 07-12-2006 10:16 AM
