Voltage draw NORMAL? - JeepForum.com
post #1 of 6 Old 01-08-2007, 11:30 PM Thread Starter
4.0H.O.XJ
So, I installed guages about a month ago.
Now, Ive noticed whenever the blower motor/defrost is on the voltage dips down right around 12 volts, and stays there until I turn it off. Its usually right around 13.5 any other time.
No other accessory draws nearly as much on it. Even with the stereo, amp, headlights, and wipers on, Im still charging at a little over 12.5.
So, what's up? Is this normal? Or is it alternator time?....or worse yet, is there a weak circuit somewhere in the blower motor system?.....I dont like it.........
*Word of note. Battery is NOT going dead, nor are the lights dimming when I do this. It's just bothering me that the system is at nuetral charge status with the blower motor going.
Thanks.......
4.0H.O.XJ is offline
post #2 of 6 Old 01-09-2007, 07:11 AM
basso4735
basso4735's Avatar
1997 XJ Cherokee
my voltage dips quite a bit when i have the blower on. i hope its normal haha.
- Includes bastard pack and cheap 3" lift info
Red 97 XJ Sport 5 Speed - Lifted 3" - Sound system - C4X4 Tow Hooks - Hella 500s
Black 96 XJ Classic - Stocker on 31s - SOLD
basso4735 is offline
post #3 of 6 Old 01-09-2007, 07:18 AM
XJING
Could be a heck of a lot of resistance caused by a loose ground or rotting connections on the blower moter circuit. Electric fans use some amps though, my dual flex a lites eat 20 amps... so I notice a slight drop when they kick on. But in your case its either a worn moter or bad connerctions...Good Luck
Originally Posted by FleXJ the Kid
Yes, probably, I dont know. I could but sometimes it was difficult. Just get under there and try.
XJING is offline
post #4 of 6 Old 01-09-2007, 09:15 AM
bee guz
blower motor
Blower motors usually run around 30 amps, to run them, thats a big draw, as long as it don't go below 12v and stay there your ok,
The volt guage only shows the condition of the battery, not the charging rate, for that you need an amp guage....
bee guz is offline
post #5 of 6 Old 01-09-2007, 01:27 PM
wizardPC
where might you get an automotive amp guage, and how would you hook it up to the alternator?
Design previews and mad kid pics on
wizardPC is offline
post #6 of 6 Old 01-09-2007, 04:10 PM
madrabbitt
madrabbitt's Avatar
first half of that is answered by "ebay" ... only because i bought 5 of them off of ebay to install in ambulances.
second half of that depends on the alternator.
Installing HID's in stock housings is bad.
"When you see someone who needs help, help them. When you see someone who needs a hug, hug them... Help those who can't help themselves." -Sgt Andrew Tingwall, NMSP. End of watch 6-10-2009
madrabbitt is offline
averaged 10mpg with normal driving.....is that normal? PUNISHER_VETTE XJ Cherokee Technical Forum 32 10-03-2009 09:19 AM
Alternator voltage output, what is the normal range? Kettles XJ Cherokee Technical Forum 31 09-07-2009 10:22 PM
Normal voltage ckisela XJ Cherokee Technical Forum 10 05-28-2009 11:56 PM
low voltage batt draw vt_xj XJ Cherokee Technical Forum 4 09-05-2005 07:27 PM
cluster voltage gauge showing wrong voltage. BackDraft XJ Cherokee Technical Forum 7 03-12-2005 01:44 PM
