volt meter drops when in reverse? - JeepForum.com
post #1 of 3 Old 01-08-2012, 03:42 PM Thread Starter
whiteys_red_XJ
noticed it the other day when i was backing up the volt meter droped to about 10 but as soon as i went back to drive it jumped back upt about 13 anyone know if thats normal???
96 xj 3.5 rustys lift, 33x10.50x15 BFG MT, t case skid plate, front tow hooks, open front and rear diff, NP-242 T-Case 1 in drop, AW4 transmission, dana 30HP, chyrsler 8.25 stock gears, K&N drop in air filter, flowmaster 40 series, poweraid throtle body spacer
whiteys_red_XJ is offline
post #2 of 3 Old 01-08-2012, 06:10 PM
tjwalker
It's the crank sensor!
tjwalker's Avatar
That is odd..... Don't know what might be going on there if this is a "consistent" symptom. Can you reproduce this "consistently"?
For starters, with any electrical gremlin, I always start with freshening engine grounds. Basics first. Always.
99 Cherokee, 4.0 AW4, NP242
Past Jeeps: 49 Willys, 81 Scrambler, 88 Comanche
Without "data", all you have is an opinion!
tjwalker is offline
post #3 of 3 Old 01-09-2012, 11:29 AM
ChrisG96xj
NSS maybe???
ChrisG96xj is offline
amp/volt meter reading at 19 then abs light came on? Finallyajeep XJ Cherokee Technical Forum 4 01-17-2010 11:57 AM
tranny and volt meter wtf? ksmanimal XJ Cherokee Technical Forum 6 05-19-2009 10:49 AM
Volt Meter Dead!!! Need Help CG98XJ XJ Cherokee Technical Forum 2 09-20-2008 06:18 PM
Check Gauges Light *Volt Meter* XJK XJ Cherokee Technical Forum 2 04-24-2007 04:23 PM
Amp meter drops to zero! XJCrazyMA XJ Cherokee Technical Forum 5 08-20-2004 10:49 AM
