Vibration Woes - JeepForum.com
post #1 of 20 Old 08-13-2012, 05:54 PM Thread Starter
chinookgod
Vibration Woes
I hate Vibration.
Alas it can not be avoided when lifting can it.
I'm looking to dampen my vibration even more but am running out of ideas
I have a 99' XJ Sport with a 3.5 - 4" JKS lift ( Shocks, leaf springs w/wedge) An adjustable track bar, sway bar link quick disconnects, 1/2 in transfer case drop, SYE mod for TC, replaced the lower and upper control arms and pitman arm, brand new u-joints front and rear, extendable yoke axles (the front one is getting a little loose) and 33" TOYO Open Country rubbers.
I'm running out of things to adjust/replace to get these vibes down.
Any Ideas?
chinookgod is offline
post #2 of 20 Old 08-13-2012, 07:30 PM Thread Starter
chinookgod
Snap Shots
The Meat and Potatoes
post #3 of 20 Old 08-14-2012, 07:27 AM
jk_surgeonfish
When are you getting the vibes?
jk_surgeonfish is offline
post #4 of 20 Old 08-14-2012, 09:25 AM
AmbuGrl
AmbuGrl's Avatar
Why did you keep the tcase drop after you installed the SYE? They SYE is done to remove the drop.
- HM1(SW/AW)Ret USN Dec 23,1992 to Dec 31, 2012
I drive an XJ, and all of my power windows work :)
2000 Pontiac WS6 - DD
DD (Mine) Sold - 98 XJ Moss Green
(His) - 92 YJ December 2013 YJOTM
Sold - 95 ZJ
Sold - 97 XJ Red
Sold - 98 XJ
USN Jeep Club Hull #36
NAXJA #3700
Originally Posted by RacerX View Post
WTF is Clockspring??? my Jeep has digital clock
AmbuGrl is offline
post #5 of 20 Old 08-14-2012, 10:05 AM
jeepnick
I've got a '99 with 3.5" lift that I did in '00 and over 100K miles ago. No problems. Your tire wear looks irregular from your pics, zerks look dry. You don't say if this just happened, or it's always done it. Is it drive lines related,or wheel balance?
jeepnick is offline
post #6 of 20 Old 08-14-2012, 10:45 AM
SuperSam
check your ball joints and unit bearings for play. Your tires look a little over inflated based on the wear on the center. Are you 100% sure the tires are balanced? What shape are your motor mounts in? The tranny mount? Are teh cooling fans chewed up? What speeds does this occur?
SuperSam is offline
post #7 of 20 Old 08-14-2012, 10:52 AM
AmbuGrl
AmbuGrl's Avatar
Remove the tcase drop
Sold - 95 ZJ
Sold - 97 XJ Red
Sold - 98 XJ
NAXJA #3700
AmbuGrl is offline
post #8 of 20 Old 08-14-2012, 03:14 PM Thread Starter
chinookgod
Currently working on getting a fresh set of tires. Turns out I found a bent former where my track bar hooks up next to my right front tire. Causing the alignment to differ from left to right.
Any speeds above 55 an continuous from there, must of forgotten to take out the drop, some reason i convinced myself it would help not hinder.
//_l__l__,\____\,
l__|---\__l---[]IIIIII[]
_()_)--o()_)--O-)_)
Rubicon Express 4", Pro comp soft 8's on Micky Thompson Baha ATZ 33's
"Shhh! ..... Did you hear that?!?" "Yea, I think something just fell off."
post #9 of 20 Old 08-14-2012, 03:16 PM Thread Starter
chinookgod
Also looked around after reading and found a cracked left engine mount that was dry rotted.
//_l__l__,\____\,
_()_)--o()_)--O-)_)
post #10 of 20 Old 08-14-2012, 03:48 PM Thread Starter
chinookgod
Sorry I meant drag link not track bar
//_l__l__,\____\,
_()_)--o()_)--O-)_)
post #11 of 20 Old 08-14-2012, 11:10 PM
loneeagle78
1990 XJ Cherokee
I am pretty sure the majority of your problem is in the tires/rims you are running. besides tires worn out, the only balance that can be done with those rims are a "static" balance. that only takes into effect the up and down movement of the tire. a true balance will be on bothe edges of the rims. this style of rim looks good, but cannot be balanced the best to compensate for vibration, especially when we go bigger and bigger with tires. I would probably try a friends set of soft 8 rims that the tires are balanced and he doesnt have vibration, just to eliminate any other problems on your suspension end. good luck.
JEEP.......not just a vehicle.........its a lifestyle!!
loneeagle78 is offline
post #12 of 20 Old 08-15-2012, 08:48 AM Thread Starter
chinookgod
Got the rims from a friend, I agree and will probably mount my 35"s on um and use them strictly for crawling. The tranny mounts, bearings and axel play all checked out.
//_l__l__,\____\,
_()_)--o()_)--O-)_)
post #13 of 20 Old 08-15-2012, 10:46 AM
lazyxj
Posting pics on a national Jeep forum, showing your illegally removed catalytic converter, is not such a good idea. It helps give Jeep owners and the off-road community a bad name.
Catalytic converters do little to restrict performance. Get one.
2001 Sport, 4" lift, 33 X 10.50 KOs, R.E. DB, R.E.-UCA, JKS-LCA, ACOS, 8.25-4.56-TruTrac, SYE, D-30 E-locker w/alloy shafts, Hidden M8000 winch, Vanco front and ZJ rear disc brakes, Lots of armor, Towing baseplate.
lazyxj is offline
post #14 of 20 Old 08-15-2012, 12:05 PM
Armycherokee
1992 XJ Cherokee
Stick to the problem at hand he doesn't want to listen to some bash him about a cat
Armycherokee is offline
post #15 of 20 Old 08-15-2012, 08:48 PM Thread Starter
chinookgod
Seriously, mine crapped out and if you couldn't tell by the hysol, this is only temporary.
//_l__l__,\____\,
_()_)--o()_)--O-)_)
99 , cherokee , vibes , vibration , xj
AC woes... 99Greenmachine XJ Cherokee Technical Forum 1 05-10-2010 11:56 PM
AC woes! joefish76 XJ Cherokee Technical Forum 4 05-28-2009 10:02 AM
TPS woes... Peter K XJ Cherokee Technical Forum 3 01-02-2007 04:46 PM
XJ Woes Gacherokee XJ Cherokee Technical Forum 1 12-27-2004 07:58 PM
MPG woes Sprital XJ Cherokee Technical Forum 5 12-21-2004 08:01 PM
