Quantcast vibration in front end - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > vibration in front end
Old 07-27-2004, 05:04 PM   #1
ptx
please help. My 93 cherokee country has a new trak bar, sway bar links, shocks , wheel bearings, universals,but still vibrates alot between 55-70 mph. I cant find the problem . When i put it on the rack everything is tite ,but after 50mph all i have to do is hit a small bump and the front end feals like it will fall off. after decelarating it titens up and then i can keep going. i really need some help , and yes the wheels are balanced. please remember my cherokee is still completely stock.
ptx is offline   Reply With Quote
Old 07-27-2004, 05:20 PM   #2
ptx
Old 07-27-2004, 09:53 PM   #3
mikesxj
Does the Jeep have a new Steering Stablizer?
Mike
FOR SALE
2000 XJ - 3'' Skyjacker w/ full leafs - SJ T-Case Drop - SJ Steering Stabilizer - 31x10.5 BFG A/T KO's- 15x8 Mt Classic II's - Bushwacker Flares - Rustys Air Tube - 6x9 K&N - stereo - Dynomax Super Turbo Exhaust - [URL="http://s33.photobucket.com/albums/d85/Mikesxj/"]Pictures[/URL]
mikesxj is offline   Reply With Quote
Old 07-28-2004, 12:37 PM   #4
ptx
thanks for responding . no it doesnt ,realy how much vibration does it dampen. like i said it almost feels like the front end is going to fall off. ive even checked all the ball joints and kingpins.
Old 07-28-2004, 12:51 PM   #5
GottaBeJeep
I didn't see you say anything about the TRE's. Check them at both ends of the Draglink and the driver's side of the Tie Rod. How about the TRE on the Trackbar at the frame mount. It is tight, correct? Steering stabilizer doesn't fix Death Wobble, which it sounds like you have, it just covers it up.
Rock Lizard Fabrications
...Off Road Armor that's "Tough as Scales"
GottaBeJeep is offline   Reply With Quote
Glock Forum
