Vibration at around 35 mph !! - JeepForum.com
post #1 of 6 Old 10-13-2009, 07:14 PM Thread Starter
AMD_GAMER
Upon accelerating, I get vibration at around 35 mph (give or take a few mph). It sounds like it's in the drive-train, but I am not really sure. What would be some things to check. Would a bad motor mount or worn out shocks cause this? Also, I also get an intermittent humming/vibration noise when I am very lightly on the throttle (like 5% throttle). The noise comes and goes in 1 second intervals. It has been doing this for a good while and I am not sure what could be causing that noise. Any ideas?
AMD_GAMER is offline
post #2 of 6 Old 10-13-2009, 08:07 PM
xjfever
xjfever's Avatar
1995 XJ Cherokee
Could be a bad u-joint, pinion bearing, output bearing. It will be hard to know without getting under the jeep and checking everything out. If all seems good under there, you may have to remove the front shaft and see if the problem goes away. If it doesn't remove the rear shaft and drive in 4x4 to see if it goes away.
xjfever is offline
post #3 of 6 Old 10-13-2009, 08:27 PM
xhavier_5478
1992 XJ Cherokee
Are you sure you want to try removing the rear shaft and driving?
1992 Jeep Cherokee Limited
Proud
xhavier_5478 is offline
post #4 of 6 Old 10-13-2009, 08:39 PM
xjfever
xjfever's Avatar
1995 XJ Cherokee
On his model there will be no problem with doing this. With the 92 you have it will leak tranny fluid.
xjfever is offline
post #5 of 6 Old 10-13-2009, 08:50 PM
xhavier_5478
1992 XJ Cherokee
What did they change on the output shaft for the 99?
Proud
post #6 of 6 Old 10-13-2009, 08:58 PM
COLOUXJ
2010 JK Wrangler
it could also be a tire imbalance. try doing a rotation and see if it goes away. i had a vibration in the steering wheel and the jeep. it was just a slight vibration though just at 50 mph. if i went 45 it would not be there if i went 55 it would not be there
COLOUXJ is offline
New vibration Black Cherokee XJ Cherokee Technical Forum 12 05-09-2008 04:01 AM
Vibration perrysjeep 98 XJ Cherokee Technical Forum 2 01-23-2008 05:35 PM
vibration....help blackwaterjeep XJ Cherokee Technical Forum 4 11-14-2007 03:49 PM
50-55 mph vibration cnskate XJ Cherokee Technical Forum 6 11-13-2007 12:48 PM
Why do I have vibration? insurrection151 XJ Cherokee Technical Forum 8 08-02-2004 11:10 AM
