Vibrating Auxiliary Cooling Fan - JeepForum.com
post #1 of 5 Old 11-01-2003, 09:20 AM Thread Starter
Jeep Cherokee
I was sitting in my jeep drinking a coffee when the whole thing started to vibrate.. then it stopped.. then it did it again. so I popped the hood and found out that the electric fan that goes on and off every 5 seconds was vibrating pretty bad. Is there anyway I can fix this? or do I just need to buy a new fan?
Jeep Cherokee is offline
post #2 of 5 Old 11-02-2003, 02:04 PM
Dacaur
Dacaur's Avatar
2008 MK Patriot
without being able to see it, I cant offer much help, But what I would do, is remove the fan frome the truck, and hook it up to the battery to see if I can tell why its vibrating, my first guess is that it might be missing a blade....
Dacaur
99 WJ Laredo
2.5" Budget boost, 265/75/16 tires, K&N air filter
Past Jeeps:
1992 YJ 4.0, 5 speed 6", lift 33's
1992 XJ 4.0, auto, 3" lift, 31's
1999 XJ 4.0, auto, 3" lift, 31's
1985 XJ 2.5, 5 speed, no lift, 255/70/15's
Dacaur is offline
post #3 of 5 Old 11-02-2003, 08:57 PM
RockinXJ
RockinXJ's Avatar
Or it has mud on it. I thought I was going to die when I first heard mine vibrate. After washing the goo off, it worked properly again.
If you light a fire for a man you'll keep him warm for a day, but if you light a man on fire, you'll keep him warm for the rest of his life!
I ♥ Transitive Pictograph Verbalizations
RockinXJ is offline
post #4 of 5 Old 11-02-2003, 09:30 PM Thread Starter
Jeep Cherokee
wow someone replied... well earlier today I took it off and found a crack in it... so I threw on a glob of superglue and it helped a TON.. but I still dont like the fact that its probably going to come apart and rattle again.. can I buy just the fan or do I have to buy the whole assembly?
post #5 of 5 Old 11-03-2003, 08:33 PM
cheesycook
Accident Prone Bonehead
cheesycook's Avatar
You could always get a Flex-a-lite 110 and connect it to the stock power lines. They cost $110 and require a little cutting. But then you would actually be able to get your arm in to change the belts without pulling anything apart. Otherwise keep an eye open on ebay. I found one guy selling one. http://cgi.ebay.com/ebaymotors/ws/eB...tem=2440781909
If you get a stocker make sure it is a newer one. They cool better than the pre-96 models.
98 TJ 4.0 Stick 30 Lock-Right/44 True-Track,4.56. Fire RED. Optima Red top. 3" Full Traction lift, Cragar 352 Street locks w/3.75 BS. 32" BFG AT's. Sailcloth top.
tubular fenders. AtoZ Fab rockers and front and rear bumpers. TBT sportsbar and rear spreader. VDP 6 speaker bar. 2K Intake Manifold. Tuffy Speaker lock boxes. Power inverter. Cobra CB. Magellan GPS. Bed lined tub. 3core HD radiator. Olds airbox with Hummer snokle. Besttop seat covers with heaters. All running lights LED.Steering and oil pan skids. Mile Marker PE8000 winch. Currie Anti-Rock. Olympic trunk. Tuffy Console....and Buddha on the winch. :) And a child seat stained with mud.
Hermiston, ORL
, because I don't have a clue, but Stu does!
cheesycook is offline
2wd vibrating Littleg182 XJ Cherokee Technical Forum 4 10-28-2013 11:12 PM
Vibrating when going 65+ mph jspecfever XJ Cherokee Technical Forum 12 10-19-2009 09:45 AM
Auxiliary electric cooling fan ??? okjeeper XJ Cherokee Technical Forum 3 06-24-2008 08:19 PM
vibrating above 45 with sye Jeepin_XJ_101 XJ Cherokee Technical Forum 7 01-15-2007 05:46 PM
vibrating, Brakes? mideerhunter XJ Cherokee Technical Forum 2 07-26-2006 04:09 PM
