Vibes... T-case... 97+... Rusty's????? - JeepForum.com
post #1 of 4 Old 08-13-2002, 11:59 AM Thread Starter
Bill and his XJ
Bill and his XJ's Avatar
Thumbs up Vibes... T-case... 97+... Rusty's?????
Does anybody know if it makes a difference which T-case you have? I'm planning on a Rusty's 3" for my 99' Limited and I have the T-case with Full time 4wd. Just curious, because Rustys doesn't even include a T-case drop with here 3" when they do at 4.5". Also, anyone know and e-mail address for Rustys? I can't find one anywhere on there site!
Thanks Ya'll.
Bill and his XJ is offline
post #2 of 4 Old 08-13-2002, 01:25 PM
EricsXJ
The Post man
EricsXJ's Avatar
Better off just to call Rusty. Many times he is the one who actually answers the phone.
For a t-case drop, I can't think of a reason why it would matter which transfer case you have. But it will matter if you are installing a SYE using a kit that replaces the output shaft. No problem with the RE SYE however - just hack it off Seriously though, if you get vibes, I would recommend a SYE over a transfer case drop.
Eric
2000 XJ "PROJECT RUBICON" 3-link front / 4-link rear / coilovers / running 37's on Dana 60s
My website -
EricsXJ is offline
post #3 of 4 Old 08-14-2002, 01:43 AM
cladinshadow
is the transfer case drop even worth using? Doesn't it hurt the angle on the front driveshaft? I have mine w/ my RE 4.5" but I dont know if I even want to install it.
Darren
96 XJ
"Oh, thank god. It's some sort of rescue toaster."
cladinshadow is offline
post #4 of 4 Old 08-14-2002, 02:24 AM
EricsXJ
The Post man
EricsXJ's Avatar
I don't think the front driveshaft is affected that much. I've heard transfer case drops are bad mainly because it is pulling the transmission and engine down a bit at an angle so it puts stress on the mounts.
I can't give any personal experience with using a transfer case drop but lots of people do use them. Rusty's also sells a crossmember that has a t-case drop built in without giving up any clearance like you do with a normal transfer case drop. Either way the best option is a SYE.
clad, I sold the transfer case drop that came with my kit to someone else on the board (for cheap). Since you are doing the whole 4x4 conversion and you need a different length driveshaft and all, have you considered getting a CV driveshaft and SYE from the start? I don't see any sense in creating a stock driveline when it may give you problems.
Eric
My website -
EricsXJ is offline
Rusty's t-case skid jeep-noob XJ Cherokee Technical Forum 4 10-25-2005 05:18 PM
Will a Rusty's 3" AAL give me driveline vibes? HeavyMetal XJ Cherokee Technical Forum 7 12-07-2004 11:05 AM
rusty's t-case spacers airbornexj XJ Cherokee Technical Forum 3 08-28-2004 02:30 AM
Got a case of the vibes Jammin' XJ Cherokee Technical Forum 3 02-03-2003 11:08 PM
Trans case vibes/ warrenty outdoorsman02 XJ Cherokee Technical Forum 3 04-14-2002 08:35 PM
