Very poor mid to high rpm performance. - JeepForum.com
post #1 of 2 Old 03-14-2011, 08:23 PM Thread Starter
Hollyhood
I have a 96 cherokee inline 6. Ill start with the known issues. #1 transmission needs drained and filter needs replaced. recently on the highway its started shifting back n forth between drive and overdrive so im sure thats part of the problem. It also has a cracked header and possibly an exhaust leak. But now on the highway it will not go over 65mph. I held it to the floor for a few seconds and it wont budge over 3500rpms. It seems to still have decent pickup driving in town. Definetly not what it had before. I guess Im trying to figure out what the main part of the problem could be. Im on a bit of a budget and trying to fix one problem at a time. I just changed the oil and replaced the sparkplugs, wires and distributor cap and rotor. any help or advice would be great. thanks.
Hollyhood is offline
post #2 of 2 Old 03-14-2011, 10:11 PM
dbgillilan
1992 XJ Cherokee
Check out these forums to help with your transmission problems.
http://www.jeepforum.com/forum/f11/s...-rpms-1180200/
http://www.jeepforum.com/forum/f12/w...sensor-605430/
I replaced throttle position sensor for less than $40.
dbgillilan is offline
motor , performance , transmission
high performance coil? jebmccall XJ Cherokee Technical Forum 15 11-04-2012 06:22 AM
96 XJ Poor mileage / Performance Timber96 XJ Cherokee Technical Forum 4 07-26-2009 09:22 AM
Poor Performance & Mileage SavageFD9 XJ Cherokee Technical Forum 1 07-17-2008 09:49 AM
What is the cause of my bad MPG/poor performance? Calpolyclimber XJ Cherokee Technical Forum 17 06-16-2004 07:31 PM
high oil preassure cause poor gas mileage? xjmatt XJ Cherokee Technical Forum 7 09-05-2003 04:43 PM
