#1 | |
Junior Member
ventilation problems
I have a '96 XJ with 220K miles with a problem in the ventilation (i.e. air vents)-- the air cuts out while the engine is under load (hills, accelerating). This holds true with the A/C on or heat, at any blower speed, and in any position of the vent control slider. As soon as I back off on the gas pedal, the air returns. Can anybody explain this?
Thanks!
#2 |
Drivin' me nuts...
Sounds like a vacuum leak.
'99 Classic: "Emma" 8.25 * NP242 * Auto trans * 3" OME HD lift * IPF lenses and H4s * Uniden PC78elite JKS Discos and adjustable track bar * 31" BFG T/A KOs on 15x8 black Cragar soft 8s Tom Wood's SYE and custom drive shaft * Custom evil shark mouth skid plate * Hingeless 2-way hood vents Jeeps with Teeth #1 MN Jeeper #14 _____________________________________________ "When is the best time to do things? Who is the most important one? What is the right thing to do?" "BORN TO WHEEL" PRODUCTS FOR SALE **********More designs here********** |
#3 |
Junior Member
Alright, thanks...I never thought of that possibility. I just remembered the one consistent thing is that the air would shift from floor or vent to the defrost vents no matter what position the control was in. Always on hills or accelerating.
Any suggestions as to how to cure this? Last edited by unit861; 02-11-2010 at 11:01 PM.. |
#4 |
I'm not sure that's a Vac leak because if there's a leak, it will be worse at idle rpms compared to cruising rpms...I'm not an HVAC pro though but I thought I would use some logic
'99 XJ Sport MY BUILD Thank You Hooligan!!! XJ/TJ Heaterbox Seals for sale!!! NIB! Official Mopar made in USA! |
#5 |
I have this same problem. I always thought that's just how it was. haha so I would be very interested in this. In mine it sounds like the blower is continuing to blow, but the air just isnt getting through. as if the blend door closes for some reason.
Utah jeep crew member #32 |
#6 | |
98 XJ 4.0 AX15 03 Wj overland sold what junk!!! 06 wk 3.7 |
#7 |
Start at the vac canister in front and follow the vac lines looking and feeling for cracks and breaks! Look under the battery, Mine leaked there, My vac line looked like it was eaten by battery acid I replaced about a foot of line.
2000 Jeep Cherokee Sport. |
#8 |
Thanks from me guys. thats some good info.
#9 |
Drivin' me nuts...
You actually get less vac with more load on the engine. My '51 Kaiser has wipers that run on a vacuum pump. Speed up and the wipers slow down. It's pretty funny.
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
