Vehicle Security System(alarm) has taken over my 1997 Cherokee. - JeepForum.com
post #1 of 2 Old 01-24-2012, 11:25 AM Thread Starter
Cotrain112
First the dome light would not turn off. I check all door sensors and they mechanically function correctly. I woke up to find the battery dead, no big surprise, when I went to jump it I found out I have a very loud alarm system. I cut the wire to the siren to keep from waking my neighbors at 5am. The Jeep would still not start, light turned on when cables were hooked up but neither the starter or engine showed any signs of life. I put in a new battery and reattached the wire I cut to the siren.
This is where I am now. When I attach the battery the dome lights turn on and the siren sounds. I can not get the siren to turn off, the engine and the starter are still not responding, and the dome lights will not turn off.
With all doors locked when I connect the battery I have unlocked the door and attempted to start...alarm still sounds and engine is non-responsive. I have turned the key in the back door back and fourth (read it online), alarm still sounds engine is non-responsive.
I have remote entry's that have working battery's but do not work(red light does light up when I press a button).
Is there a fuse I could pull?
Can I just pull the entire stupid security system out?
I am no mechanic but this seems like a simple issue that I should be able to solve myself without dropping $100.
My objectives: Get siren to shut off when battery is attached.
Get engine to start. (I really hope I do not have bad starter)
Get dome lights to turn off.
Any advise would be appreciated.
Please Help!
Cotrain112 is offline
post #2 of 2 Old 01-24-2012, 12:15 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Most aftermarket alarms have a Valet pushbutton switch to allow starting without a remote, and a toggle switch to disable the alarm system. It might be reasonable to assume that the alarm system is faulty.
The dome lamp issues may or may not be alarm related. Check the headlamp switch dome lamp function and check the door switches for short circuits or failure.
CJ7-Tim is offline
1991 Cherokee Limited factory Security system and/or NuStart System pathfinder76 XJ Cherokee Technical Forum 1 10-01-2014 09:47 AM
jeep cherokee XJ 98 security alarm zino XJ Cherokee Technical Forum 9 02-17-2011 09:59 AM
Security/theft system on '99 cherokee DavidJackson XJ Cherokee Technical Forum 4 11-06-2009 01:09 PM
Disable security system on 97 Cherokee T.Maxwell XJ Cherokee Technical Forum 1 04-02-2009 02:23 PM
'96 Cherokee security system? White-Knight XJ Cherokee Technical Forum 4 08-16-2002 09:20 AM
