valve cover gasket replacement - JeepForum.com
post #1 of 6 Old 01-18-2005, 11:35 AM Thread Starter
mh89xj
I just had a few questions about changing my valve cover gasket. I'm pretty much a newbie when it comes to engine work. Is this something I can do myself? how long should it take? Once the valve cover is off, is it difficult to remove old gasket? is there anything i need to do to prevent crap from falling into engine? Is there any thing else I need to know before I start? i don't have a torque wrench. does autozone offer them as loaners?
I've read about some people changing there own, but couldn't find any detailed instructions. i have a Haynes manuel, but can't find anything in it about changing the valve cover gasket
thanks
89 XJ Laredo
222,000k
4-Speed Automatic AW4 Transmission
Dana M30 Front Axle Dana M35 Rear Axle
3.55 Axle Ratio
BDS 3" lift w/ 31x10.50 Pro Comp MT's
mh89xj is offline
post #2 of 6 Old 01-18-2005, 11:40 AM
twisted_ed
twisted_ed's Avatar
im sure somewhere in there theres a place that tells you how to change it.. but basically you need to remove any hoses comming out of it those are thebreather and ccv hoses if so equiped and then remove the bolts holding it down.. be carefull not to strip or break any bolts.. and trick can be to get the engine running temp so all the metal expands then loosen the bolts and remove them more easyer.. then pull the cover off. it may be a little stuck but tapping it with a rubber mallet will cure that... pop it off and cover the inner workings of the engine with a rag to make sure that -=-=-=-=-=-=-=-= doesnt get on there then scrape the old gasket off and put a new one on. reverse the steps. you may have some gasket on the engine too that needs to be scraped off, just be carefull not to get any into the inner workings.
1990 Jeep Cherokee Laredo
4.0L
Automatic Tranny
NP242 Transfer case
Dana 30 front, 35 custom rear differentials
Mods:
RE 4.5" Lift
32x11.50 BFGoodRich M/T KM's
American Eagle 058 Polished Aluminum Wheels, 3.63" BS.
Grand Cherokee Rear Disc Brake setup
Custom Downpipe W/ Cat Removed.
Dynomax Super Turbo Muffler.
Surco Roof Rack
twisted_ed is offline
post #3 of 6 Old 01-18-2005, 12:30 PM
drag1320ft
just use blue stuff, no gasket required..... Valve covers are not usually torque specific because their only functionality is to keep oil in and dirt out. Just don't over tighten or you will strip the threads in the head.
Michael
"Be careful how you think; your life is shaped by your thoughts"
proverbs 4:23 (TEV)
drag1320ft is offline
post #4 of 6 Old 01-18-2005, 04:22 PM Thread Starter
mh89xj
thanks for the advice
went to advance today. bought fuel filter, valve cover gasket and a small tube of RTV. now I just have to wait for it to warm up. seems simple enough. i'll just take my time.
figures last week, when I was out of town, it was in the 60's. now that I'm back, it's in the teens!
89 XJ Laredo
222,000k
3.55 Axle Ratio
mh89xj is offline
post #5 of 6 Old 01-18-2005, 04:53 PM
Altec88
Altec88's Avatar
make sure you seal it good, or it'll leak like my 2.5 did...
Altec88 is offline
post #6 of 6 Old 01-18-2005, 05:04 PM
xj-xile
xj-xile's Avatar
Just a note: if your valve cover is warped, it will leak no matter how hard you try to seal it. Once you get it off, lay it on a flat surface & see whether it is warped.
A gasket scraper is very handy for getting the old RTV seal off. Scrapers are available at www.summitracing.com but I think they should be available at places like Autozone . . . maybe.
I replaced the RTV seal on mine TWICE & it still leaked (b/c I was impatient, didn't let it set up long enough, & then didn't let it dry long enough). So I finally had the mechanic do it. He used both a gasket of some kind as well as the RTV sealant. Now no leaks (well, I also had to have the oil filter housing re-sealed w/new O-rings, & had to have my rear main oil seal replaced, then I had no more leaks).
xj-xile is offline
Valve cover gasket replacement mooncheese100 XJ Cherokee Technical Forum 13 09-01-2011 10:19 PM
Need help with valve cover gasket replacement nasars XJ Cherokee Technical Forum 27 04-21-2010 06:44 PM
'00 Valve Cover Gasket Replacement Jamo33 XJ Cherokee Technical Forum 2 03-13-2008 05:46 PM
Valve cover gasket replacement???? spinfly XJ Cherokee Technical Forum 5 11-21-2006 02:26 PM
Valve cover gasket replacement fourlow XJ Cherokee Technical Forum 1 07-12-2006 04:54 PM
