valve adjustment - JeepForum.com
post #1 of 33 Old 08-19-2012, 12:08 PM Thread Starter
snowcat
valve adjustment
hey guys i got a 1988 jeep Cherokee limited inline 6 4.0. and i need to adjust my valves how would i adjust my valves because i have loose valve and needs to be adjust but dont know how. could you guys give me some pointer on how to adjust them because my master mechanic buddy is gonna be helping me and idk how and i dont got specs on what the adjustments need to be such as torque and how tight they need to be thank you
snowcat is offline
post #2 of 33 Old 08-19-2012, 12:13 PM
Motorcharge
You can't adjust the valves in the 4.0. What makes you think it needs adjusting?
|SOLD|
| June 2015 COTM |
Motorcharge is offline
post #3 of 33 Old 08-19-2012, 12:19 PM Thread Starter
snowcat
they seem loose could i double check the torque or what idk thats what my buddy said ticks under a load such as driving but not at ideal
snowcat is offline
post #4 of 33 Old 08-19-2012, 12:19 PM Thread Starter
snowcat
like it tick everytime im driving but not when park online when im driving and giving gas
snowcat is offline
post #5 of 33 Old 08-19-2012, 12:20 PM Thread Starter
snowcat
only not online
snowcat is offline
post #6 of 33 Old 08-19-2012, 12:37 PM
Motorcharge
The injectors are fairly loud on the 4.0 and can make a ticking sound. The stock exhaust manifold is also prone to cracking and makes a ticking sound as well when it does. I'd start on checking those first.
|SOLD|
| June 2015 COTM |
post #7 of 33 Old 08-19-2012, 12:43 PM Thread Starter
snowcat
well i dont under stand how it could be injectors because when i pop hood and rev from top of engine doesnt make noise only when im driving thats about it
snowcat is offline
post #8 of 33 Old 08-19-2012, 12:47 PM Thread Starter
snowcat
coming from back of the engine on top thats where im hearing noise
snowcat is offline
post #9 of 33 Old 08-19-2012, 12:49 PM
Motorcharge
How long have you had it? Is the oil full and when is the last time it was changed? The 4.0 takes 6 qts of oil. Have you ever cleaned the fuel system and motor with seafoam or something similar? Could be sticking lifters.
On an unrelated note you have an XJ Cherokee, not a full size.
|SOLD|
| June 2015 COTM |
post #10 of 33 Old 08-19-2012, 12:58 PM Thread Starter
snowcat
im do oil change tuesday its full on oil im put some sea foam in that stuff always cleans well so ima try it thanks man ima put full can of sea foam in oil and full thing in gas and whats diffrent on size what you said last
snowcat is offline
post #11 of 33 Old 08-19-2012, 01:00 PM
Motorcharge
Full size Cherokees are the old ones from 74-84.
|SOLD|
| June 2015 COTM |
post #12 of 33 Old 08-19-2012, 03:05 PM Thread Starter
snowcat
could it do anything with my tranny ???
snowcat is offline
post #13 of 33 Old 08-19-2012, 03:31 PM Thread Starter
snowcat
since it has push rods
snowcat is offline
post #14 of 33 Old 08-19-2012, 03:33 PM Thread Starter
snowcat
dont you put filler gage between rocker and valve???
snowcat is offline
post #15 of 33 Old 08-19-2012, 04:31 PM
djb383
Negative, there is no manual valve adjustment. It is a "zero" lash hydraulic valve train. It adjusts itself automatically.
djb383 is offline
Valve Adjustment & Valve Spring Replacement srpope80 XJ Cherokee Technical Forum 6 05-29-2014 05:45 AM
PCV/other valve on valve cover leaking CJ7RX7 XJ Cherokee Technical Forum 10 04-12-2010 12:18 AM
Valve stem seals? or valve lash? Godchsr XJ Cherokee Technical Forum 9 11-29-2007 01:28 PM
help me do a valve adjustment thesplintercell XJ Cherokee Technical Forum 3 04-15-2007 01:49 PM
Coolant Mixing Valve / Heater Valve Leaking - Tips needed JWeb_93YJ XJ Cherokee Technical Forum 5 03-13-2005 07:34 AM
