Vacuum Reservoir - JeepForum.com
post #1 of 10 Old 08-16-2009, 04:08 PM Thread Starter
Finaltheorem47
1992 XJ Cherokee
Vacuum Reservoir
What does the vacuum reservoir do? I removed it and plugged the line when I put a new bumper on because it wouldn't mount where it used to.
Finaltheorem47 is offline
post #2 of 10 Old 08-16-2009, 04:22 PM
xjfever
xjfever's Avatar
1995 XJ Cherokee
It conserves vacuum to run your cruise control and vent selection for the heat/air when you are at higher rpms and lose manifold vacuum. If your vents go to the defrost selection when at higer rpms, or your cruise control doesn't work anymore you can relocate it to the engine compartment.
xjfever is offline
post #3 of 10 Old 08-16-2009, 04:23 PM
ehall
1991 XJ Cherokee
It essentially stores vacuum so that there is always some available to drive the accessories on that line (AC vent control, heater control valve, and cruise control). Think about the way engines work here--pistons create vacuum when they suck air through the intake manifold. Usually this air comes in through the throttle body. However when the throttle blades are closed the engine is not able to suck in as much air, and the vacuum pressure in the manifold goes up. Conversely when the throttle blades are open (acceleration) the engine is able to suck in lots of air through the throttle body, so there is less overall vacuum pressure in the manifold. In turn, accessories that need vacuum to operate are starved out during acceleration (do a quick acceleration and step on brakes, they will be really weak). This results in things like air conditioning flopping around the different HVAC vents because not enough vacuum to keep the selected outlet open, or having the cruise control cut itself off because there is not enough pressure to maintain the valve.
As for the canister, when the vacuum is being pulled through the manifold and lines, the air that is naturally present in the canister gets sucked out, resulting in negative pressure in the bottle. When the manifold vacuum dies out during acceleration, the air pressure in the canister tries to normalize with ambient air pressure, which means that the canister is now sucking air out the accessory lines, which means that it becomes the vacuum source for the accessories on that line.
ehall is offline
post #4 of 10 Old 08-16-2009, 05:06 PM
Magus2727
1995 XJ Cherokee
can't add much to what has already been said but it also holds a a vacuum for quite some time after the motor is off. that's the rushing of air sound that you get when the vehicle is off but you adjust the climate control settings.
NAXJA Member #2619
1995 Jeep Sport Cherokee 4x4 with an Auto and 4.0L
B&M Transmission Cooler and Autometer Tranny Temp Gauge, Ruff Stuff Diff Cover on D30.
Taraflex 1.5" BB (rear shackle only), HD Quadratec leaf springs, RE 3.5" front springs, OME Long shocks, JKS Adjustable Track Bar from K.O.R.
Daystar Control Arm Bushings, Bushwhacker Flairs, Rhino lining along bottom trim, AGR PS pump with Cooler & Filter.
Bored TB, APN Manifold, New Downpipe, Magnaflow High Flow Cat, Flowmaster Super 44.
Dual Oil Relocation Kit running two K&N301 size filters, Autometer Digital Cobalt Oil Temp and Oil Pressure Gauge.
Magus2727 is offline
post #5 of 10 Old 08-16-2009, 05:39 PM Thread Starter
Finaltheorem47
1992 XJ Cherokee
Thank you for your replies. My HVAC has functions fine, but the cruise control doesn't work. I don't believe the cruise control worked before I took it off though.
I am unsure because when I got the Jeep, I tore it apart before I started driving it, so I am just going off of what the previous owner told me.
I am pulling about 16 inches of Mercury though at idle. Will the reservoir effect braking at all? I am already planning to re-install it now, but I'd just like to know. Will some fuel line hose work well enough to use when I relocate it?
post #6 of 10 Old 08-16-2009, 08:58 PM
ehall
1991 XJ Cherokee
That's a good number for idle.
Not by design. There is supposed to be a check valve on the accessory line at the firewall, which will prevent vacuum pressure from going back into the manifold. If the check valve is broken or missing then yes the bottle will be a vacuum source for everything else that is attached to the manifold. .
Fuel and heater hose are hard to use since they are not as flexible and pliable. You end up getting too large a size, and then it does not seal as well and you lose vacuum pressure. Better to get real vacuum hose that is just a little too small, and use silicone dielectric grease to lubricate and seal the connectors.
ehall is offline
post #7 of 10 Old 08-17-2009, 12:24 AM Thread Starter
Finaltheorem47
1992 XJ Cherokee
Okay, thanks.
post #8 of 10 Old 08-17-2009, 10:40 AM
XJohnnyC
XJohnnyC's Avatar
On my 92 MJ, I got a reservoir from a 97+ XJ. They're round and smaller than the pre-97 oblong-shaped ones. So it's easier to find a nice spot to relocate it.
XJohnnyC is offline
post #9 of 10 Old 08-17-2009, 03:57 PM
Matt Gertsch
www.lp.org
Matt Gertsch's Avatar
I've got a cone intake, so I was able to put mine where the air box used to be. I was able to reroute the hard lines and use only limited vacuum hose. Make sure you keep the check valve in place on the manifold and the one near the firewall.
Derpy Hooves for President in 2012
Matt Gertsch is offline
post #10 of 10 Old 06-03-2013, 10:23 PM
JeepJohn92
1988 XJ Cherokee
Im having issues with my vacuum lines and less than satisfactory idle. Would a bad canister kill my idle speeds? Ive unplugged the lead from the cannister to my manifold and the RPM's at idle and in gear are much better. Im lost on this one.
Colorado Jeep Club Member #343
Built not bought.
JeepJohn92 is offline
Relocating vacuum reservoir for offroad bumper ryguy0019 XJ Cherokee Technical Forum 7 09-26-2010 01:38 PM
pictures of vacuum VS non vacuum axles needed snowrydr01 XJ Cherokee Technical Forum 1 01-28-2009 01:58 PM
moving vacuum reservoir Matt Gertsch XJ Cherokee Technical Forum 5 02-08-2008 04:29 PM
Vacuum Reservoir ? rworks MJ Comanche Technical Forum 7 08-14-2007 08:19 PM
where are the vacuum lines to the front vacuum canister??? Elliottm2333 XJ Cherokee Technical Forum 3 03-13-2007 10:26 PM
