vacuum problem.. - JeepForum.com
post #1 of 7 Old 08-08-2010, 03:02 PM Thread Starter
dilla21
vacuum problem..
just noticed that the vacuum line that connects to the front diff was dragging on the ground (still connected to the pass side of the diff). Where exactly does the other end tap into? I cant find a vacuum block anywhere/noob. thanks
dilla21 is offline
post #2 of 7 Old 08-08-2010, 03:27 PM
Holder350
1995 XJ Cherokee
If you are referring to the axle disconnect, it should run back to the transfer case to a vacuum switch.
95' XJ Country - Stock Skids - D30/D35 Limited Slip - 3" Lift - 31x10.50R15 - 4.0 HO - AX15 - NP231
98' XJ Classic - D30/C8.25 - 4.5" RC Lift - 33x12.50R15 - 4.0 HO - AW4 - NP231
Originally Posted by Azzy View Post
You can tell the character of a person in how they treat someone who can do nothing for them.
Holder350 is offline
post #3 of 7 Old 08-08-2010, 03:40 PM Thread Starter
dilla21
would this hose connect to the t-case or a vacuum log in the engine comp? like i said, new to jeeps..
dilla21 is offline
post #4 of 7 Old 08-08-2010, 04:21 PM Thread Starter
dilla21
where would this vacuum switch be? by the speed sensor?
dilla21 is offline
post #5 of 7 Old 08-08-2010, 04:46 PM
Holder350
1995 XJ Cherokee
Right by the red ID tag
post #6 of 7 Old 08-09-2010, 06:54 PM Thread Starter
dilla21
got it figured out holder, it was the breather hose.. thanks for the input!
dilla21 is offline
post #7 of 7 Old 08-09-2010, 07:06 PM
Holder350
1995 XJ Cherokee
Cool deal man, glad it was a simple solution
4wd , vacuum lines
Vacuum Problem? Doitsouthstyle XJ Cherokee Technical Forum 2 04-28-2010 06:43 AM
Another Vacuum Problem :0 dug320 XJ Cherokee Technical Forum 2 04-25-2010 10:38 PM
Vacuum Problem.... edolivett XJ Cherokee Technical Forum 5 12-17-2007 12:18 AM
86 xj vacuum problem noir XJ Cherokee Technical Forum 8 07-28-2006 09:37 PM
Troubleshoot vacuum problem???? SoloHiker XJ Cherokee Technical Forum 2 10-30-2005 09:09 AM
