Vacuum lines diagram - JeepForum.com
post #1 of 13 Old 05-19-2009, 10:20 PM Thread Starter
funnynyck
for a 1996 Cherokee XJ, any idea where can I download it? Trying google, no luck so far.
Brake is acting weird, pedal feel not good, whenever I floor the throttle pedal the A/C Blower changes ducts from the front ones to somewhere else, no air comes out from the vents but i can hear blower working 'woooooooo' and gets back to the front vents slowly when i release the throttle... The jeep starts and coughs for some seconds and then gets up slowly, press the throttle even slightly it goes off. And it nevers starts on the first crank, no matter how long you keep it cranking.
I tried chasing the vacuum lines, I was going bonkers chasing them. Since I don't know much about how they work as well, could someone be generous and explain in simplest form that how that vacuum system works, for a start..
funnynyck is offline
post #2 of 13 Old 05-20-2009, 12:37 AM
keepishop
1989 XJ Cherokee
Check the vacuum canister in your bumper for leaks in it or the lines leading to it. Most common sign of it's failure is air out the defrost vents only.
Current: Black 89 limited, dakota bastard pack, zj coils, 1.5" lift, open cooling swap,
Rest in Pieces: Red 1990 cherokee dana30/8.25 - v8 zj coils & s10 bastard pack 2.5" lift - 31x10.5r15 tires - v8 zj tierod
Originally Posted by talentjeep View Post
Bleed or Quit.
jf irc @ irc.freenode.net #jeepforum
keepishop is offline
post #3 of 13 Old 05-21-2009, 07:27 AM Thread Starter
funnynyck
Mine is not in the bumper, its placed near the firewall, where I think the blower motor is.. mine is a RHD btw.
I've checked the canister, it seems to be okay, the third inlet/outlet/slot w/e it is, has to be connected or not? I've three slots on the canister, and 1 of them isn't connected to anything..
post #4 of 13 Old 05-21-2009, 08:48 AM
Saudade
1988 XJ Cherokee
Try using the search function in this forum.
You canister was relocated. You likely have a custom bumper so the PO moved it. Yes, all fiittings should have a line or cap. The reservoir holds vacuum for the HVAC vents and the Cruise Control.
Saudade is offline
post #5 of 13 Old 05-21-2009, 11:43 PM Thread Starter
funnynyck
I don't think that it was relocated, the PO didn't bother to change its engine oil, let alone doing something like relocating the canister, it must have to do something with LHD and RHD, mine is a RHD. I don't have a custom bumper or anything, its all stock except the steering gearbox.
And I used the search function, yes there are diagrams, but I need something for a 1996 XJ, and clear, not small that I go on finding those things in the diagrams first..
post #6 of 13 Old 05-22-2009, 07:00 AM
khurley
I also have a 96 cherokee, and my canister is also against the firewall.
I just put in a reman, and now I only get air blowing through the defrost vents. the jeep is also hesitating and backfiring, is that what yours is doing?
sorry I didn't have much to offer, but I am having some of the same issues.
khurley is offline
post #7 of 13 Old 05-22-2009, 07:58 AM Thread Starter
funnynyck
Yeah, when it starts up I have to let it idle rough for a few seconds, If i press the throttle it backfires and dies.. and then starts up just fine..
You could have the diagrams maybe? If you could email them to me, that'd be great.. My vents system is working fine..
and Oh, the brake pedal feel is nasty aswell, its not soft, not hard, its well *slow*..
post #8 of 13 Old 05-22-2009, 08:04 AM Thread Starter
funnynyck
it also sometimes revs itself to 3k RPMs and thats well, really really nasty!
post #9 of 13 Old 05-22-2009, 08:08 AM
Saudade
1988 XJ Cherokee
Are you sure it's the vacuum reservoir and not the Evap canister?
When under heavy acceleration, the engine operates at low vacuum. If there's a leak, then there's not enough vacuum to maintain the door positions and they default to Defrost. Once you back off, the engine vacuum rises and the doors go back to normal. A big enough leak would affect eng op as well.
While climbing up mountain passes, my cruise control (also vacuum operated) will quit until I cross the summit.
I don't have a 96 manual but will check. You can also try Autozone.com. The have repair guides online. You have to register, but it's free.
Saudade is offline
post #10 of 13 Old 05-22-2009, 11:54 AM Thread Starter
funnynyck
I dont know what is an evap canister, thats why i needed to know how the vacuum system works.. what goes where..
Do care to tell me about the vacuum reservoir and the evap canister.
post #11 of 13 Old 05-22-2009, 03:22 PM Thread Starter
funnynyck
Here is the pic: What this bottle is? EVAP canister or the vacuum reservoir?
Note that one of the inlet/outlet is not connected / not capped.
post #12 of 13 Old 05-22-2009, 07:16 PM
Saudade
1988 XJ Cherokee
Yep, that's the evaporative canister for the emissions. The vacuum reservoir is behind the pass side front bumper. At least, it is on a LHD vehicle.
Saudade is offline
post #13 of 13 Old 07-06-2009, 09:28 PM
audiemurphy
Did you guys ever figure out what was going on with your jeeps? I have pretty much the same problems, 5 second start up, rough idle at first, a/c going to defrost while climbing a hill, but without the backfire. I am trying to figure out how to perform a vacuum test on this and any help would be appreciated.
I was thinking it was my fuel pump since its reading 36psi until i saw this thread.
96 xj country.
96 Cherokee country, 4.0l inline 6.
audiemurphy is offline
vacuum diagram Nick85 XJ Cherokee Technical Forum 0 10-28-2009 10:39 PM
89 4.0 Vacuum Diagram bmdsoccerbum XJ Cherokee Technical Forum 0 08-05-2009 03:48 PM
where are the vacuum lines to the front vacuum canister??? Elliottm2333 XJ Cherokee Technical Forum 3 03-13-2007 09:26 PM
Vacuum Canister & Vacuum Diagram saxj XJ Cherokee Technical Forum 9 05-06-2005 02:08 AM
vacuum diagram JVracer04 XJ Cherokee Technical Forum 3 03-07-2005 10:45 AM
