Vacuum line at throttle body - JeepForum.com
post #1 of 3 Old 08-26-2016, 09:52 PM Thread Starter
Qchunter
1989 XJ Cherokee
Question Vacuum line at throttle body
On my renix XJ, the vacuum line between the map sensor and throttle body is very brittle. Found the the PO taped the end and stuck it in the throttle body where it should go. I am fixing that issue but the grommet on the throttle body has 2 holes? Should there be a second vacuum line coming from somewhere else?
89 XJ 4x4 3" Pro Comp, 4.0, AX15
bought 8/7/16 so still learning
Qchunter is offline
post #2 of 3 Old 08-27-2016, 07:50 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
One hole has vacuum and the other hole holds the plug. Wanna fix it for good?
Click on the link below.
http://cruiser54.com/?p=280
If you own a Renix Jeep, you must check this out:
My Jeep technical photos:
cruiser54 is offline
post #3 of 3 Old 08-27-2016, 08:17 AM Thread Starter
Qchunter
1989 XJ Cherokee
Perfect
I missed that one on the list.
Qchunter is offline
