Vacuum and the 231 - JeepForum.com
post #1 of 4 Old 08-16-2002, 02:05 AM Thread Starter
cladinshadow
Vacuum and the 231
How essential is the vacuum to the 231? I don't have it hooked up to any vacuum at all, and i just finished converting my jeep to 4 wheel drive. The transmission and transfer case are having trouble taking the power from the engine and turning anything. The transfer case and transmission can be in any gear and it won't turn a damn thing. It's filled w/ ATF, too. Figures, I finally get done converting and lifting my jeep only to find the transmission/transfer case i got don't work.
Darren
96 XJ
"Oh, thank god. It's some sort of rescue toaster."
cladinshadow is offline
post #2 of 4 Old 08-16-2002, 06:35 AM
johny1i
johny1i's Avatar
If you're talking about the NP231 that us Wrangler guys have, the vacuum is only for a switch on the top of the TC that sends vacuum to our front axle when the TC is shifted to 4WD (the front axle has a vacuum-operated disconnect). The vacuum has nothing to do with the operation of the TC, and in fact many guys replace the vacuum setup with a cable to the front axle, thus eliminating the vacuum lines going to the TC entirely.
Currently an '86 CJ-7 and a '77 CJ-7 Golden Eagle---#4 and 5 following a '01 Sahara, '90 Sahara, and '85 CJ-7....
johny1i is offline
post #3 of 4 Old 08-16-2002, 06:38 AM
johny1i
johny1i's Avatar
I couldn't tell from your post what kind of transmission you put into it, but if you installed an automatic and the torque converter isn't full of fluid, nothing will happen (it will just spin). The torque converter must be filled prior to installation (or at least that's what we had to do)--some of these other guys may have ways to do it after the fact. I had the same exact problem with an old Powerglide transmission.
johny1i is offline
post #4 of 4 Old 08-18-2002, 09:00 PM Thread Starter
cladinshadow
The torque converter wasn't full, but it was drippin fluid when we put it in. It's at the 4x Doctor, an awesome shop in Burbank, Ca, and hopefully they'll be able to give me a little more information. The weird thing is that it won't spin anything but when i put it back in park w/ the engine on, it makes a weird clanky / grinding noise. But only to park. =c\
Darren
96 XJ
Dana 30 Vacuum/Non-Vacuum Question 89SAFARIXJ XJ Cherokee Technical Forum 28 05-22-2009 04:16 PM
d30 vacuum to non vacuum olblue87xj XJ/MJ Cherokee Non-Technical Forum 1 02-05-2009 06:15 AM
pictures of vacuum VS non vacuum axles needed snowrydr01 XJ Cherokee Technical Forum 1 01-28-2009 12:58 PM
where are the vacuum lines to the front vacuum canister??? Elliottm2333 XJ Cherokee Technical Forum 3 03-13-2007 09:26 PM
Vacuum Canister & Vacuum Diagram saxj XJ Cherokee Technical Forum 9 05-06-2005 02:08 AM
