Using a spacer and a drop shackle to get an extra inch out of my lift, is that ok? - JeepForum.com
post #1 of 6 Old 05-17-2013, 09:51 PM Thread Starter
Xride
Have the Old man EMU lift, and want an extra inch or so, is there any reason not to just use a spacer up front and a list shackle in the rear? Is there a better way without new springs and leaf springs?
I have adjustable control arms, track bar, and a SYE already.
Thanks,
99 XJ, black, 4x4, NP231, 8.25 rear. Fully locked.
5.5" long arm lift, 35x12.5x15 Kumo KL71MT
Xride is offline
post #2 of 6 Old 05-18-2013, 12:25 AM
chris87xj
JF Admin
chris87xj's Avatar
1987 XJ Cherokee
Spacer and shackle lift is fairly common and not too bad for an extra inch or so of adjustment.
***Chris***
chris87xj is offline
post #3 of 6 Old 05-18-2013, 05:55 AM
Motorcharge
For an inch, sure. Shackle angle gets bad in the stock location if you go up to a 2" shackle without relocating them though.
|SOLD|
| June 2015 COTM |
Motorcharge is offline
post #4 of 6 Old 05-18-2013, 07:51 AM Thread Starter
Xride
Probably worth tossing the relocation in there then eh?
For some reason I thought doing the relocation bracket needed to be welded but google seems to have a couple bolt in options
Xride is offline
post #5 of 6 Old 05-18-2013, 07:53 AM
Motorcharge
They typically add some lift as well though, something to be aware of. If you're just looking for an extra inch then a 1" shackle should be fine.
|SOLD|
| June 2015 COTM |
post #6 of 6 Old 05-18-2013, 08:18 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
1-2" dog leg lift shackles work well, and have acceptable shackle angles and a full range of travel.
I prefer JKS - http://www.quadratec.com/products/16009_130.htm
CJ7-Tim is offline
