upper control arm bolt size? - JeepForum.com
post #1 of 7 Old 04-09-2009, 06:41 PM Thread Starter
jebmccall
1997 XJ Cherokee
hey what size socket and wrnech fit on the upper control arms bolts on the body side. i tried a 15 and it seemed to just slip with a little pressure. a 15 seems to fit good on the nut side but not the bolt head side. any ideas? thanks people
jebmccall is offline
post #2 of 7 Old 04-09-2009, 06:50 PM
skyway0018746
uhhh the other side you dont need a wrench its got a tang on it so it dosent move all you need is a wrench on the nut side
skyway0018746 is offline
post #3 of 7 Old 04-09-2009, 06:51 PM Thread Starter
jebmccall
1997 XJ Cherokee
yeah but ive had a few of those break before, any body know the definite sixe of that bolt.
post #4 of 7 Old 04-10-2009, 05:30 AM
skyway0018746
i just used a sawzall and cut it off
post #5 of 7 Old 04-10-2009, 05:37 AM
xjfever
xjfever's Avatar
1995 XJ Cherokee
I used the 15mm on both sides, is it rounded off?
xjfever is offline
post #6 of 7 Old 04-10-2009, 06:20 AM Thread Starter
jebmccall
1997 XJ Cherokee
no, never been touched before. ill try the 15 on hte nut side and hopefully get it off.
post #7 of 7 Old 11-30-2015, 09:32 AM
georgewastaken
I'm having the same issue with the nut side of that bolt. I rounded it off with a 6 point 15 and nothing else fits. I'm hoping to replace it with a new nut while it still has enough meat on it to unbolt but I have no Idea what the diameter/pitch of the bolt is. Anyone have any ideas?
georgewastaken is offline
rear upper shock bolt size Redneckbuckeye XJ Cherokee Technical Forum 9 12-10-2010 05:21 AM
Rear shock upper bolt size JeepJinx XJ Cherokee Technical Forum 5 08-10-2009 11:49 AM
Need bolt size for upper rear shock mounts mattathayde XJ Cherokee Technical Forum 17 05-18-2009 03:15 PM
Bolt size for upper control arm axle mount Slow86prix XJ Cherokee Technical Forum 3 07-07-2008 09:16 AM
Broken Upper Control Arm Bolt, how do I get it to line up? Iwantawrangler XJ Cherokee Technical Forum 3 10-13-2006 01:46 PM
