Quantcast Upgrading Negative Battery Cables...Lots of pics! - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Upgrading Negative Battery Cables...Lots of pics!
SALE -- Yukon Gear Free Spin Hub Conversion Kit - Dana 30 1984-2001 Jeep XJ Cherokee Lift Kits 3-4.5" with FullIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Old 08-01-2007, 03:19 PM   #1
Jmila1901
This is my step by step guide on how to remove your old small negative battery cables and install larger ones to take their place...
(I forgot to take pictures of me removing the plastic wrap around the cables, just cut the tape and pull the plastic sleeve off the battery cables to reveal them!)
Vice Grip, Ratchet with small adapter, 13mm socket, 1/2, 3/8
Brass Marine Terminals
2 gauge (or better) Battery cables... Factory length is 27in for the long side and 7in for the short side... I bought 33in and 10in, I would NOT recommend buying your cables the same size as factory because it makes it allot harder to route and put into position, the extra long cables gives you room to work with! I also got a copper end just in case i did need to shorten a cable which i didn't.
Here are the tiny old cables i ripped out... They bend with ease!
with the 1/2 remove the battery rerminal, with the 3/8 remove the ground to frame...
Unbolt the ground from the block and pull the pld cables out...
Now all you need to do is reinstall the new cables in reverse order, tighten down the brass battery post, pop the new cables in and tighten up the wing nut...
Here are the results!
Justin Mila
1993 Country XJ- AW4, 4.0 HO, Chy 8.25, Homebrew K&N Intake... DailyDriver
2002 Laredo WJ- Broken Bumper Mod... Weekend Toy
2007 Nike Dunks Size 12... Backup
Blue Jeep Club Member # 221
Originally Posted by KeepRockin024
You know your drunk when you have a little to much blood in your alcohol stream
Jmila1901 is offline   Reply With Quote
Old 08-01-2007, 03:21 PM   #2
Jmila1901
Just a note, Once i do my Positive cable upgrade i will merge my Braided engine ground upgrade thread, this thread, and the positive cable thread together
Justin Mila
Old 08-01-2007, 04:09 PM   #3
Rasta_Coty
nice man...i gotta upgrade mine..the terminals barely go on there anymore
[SIZE="1"]1996 Jeep Cherokee || 4.5 in. RC || 4.0 liter I-6 high output || 33 x 12.50 BFG All Terrain T/A KO, 16x8 American Racing rims || Rusty's Air Tube w/ K&N 9in. Cone Filter || Throttle Body Spacer || Bored TB || Flowmaster Regular 40 || 99+ Intake Manifold Swap || Auto Meter (Trans Temp. | Water Temp. | Volt) Gauges || Pioneer 5800 HU || Hifonics 1606 Amp || (2) Kicker Comp Cvr 15's || 1/0ga. wiring || Vented box || Yellow Top || Tranny Cooler || Bushwackers || [/SIZE]
[B][SIZE="3"][url]http://www.cardomain.com/ride/2218603[/url] Updated 2/4/07[/SIZE][/B]
Rasta_Coty is offline   Reply With Quote
Old 08-01-2007, 06:28 PM   #4
Shoobie
1989 XJ Cherokee
Looks beefy. This is on my list of things to do.
Shoobie is offline   Reply With Quote
Old 08-01-2007, 08:13 PM   #5
Cody_00_XJ
bookmarking this to do later
2000 XJ Sport
Here's my Jeep
Cody_00_XJ is offline   Reply With Quote
Old 08-02-2007, 12:05 AM   #6
skylander
Hey this is timely. I just got done redoing my battery lines using marine terminals. Only, I used the 4 gauge stuff with 6 gauge power and chassis ground connections. Way to go on the write up.
skylander is offline   Reply With Quote
Old 08-02-2007, 12:08 AM   #7
wojtizzlator
1987 XJ Cherokee
nice job i put new ends on mine but i wanna do the whole cable somtime in my life
Wojtek
"who needs paved roads when u have a jeep"
87 xj 6" long arm lift, 35's, 4.88 yukon gears, front detroit true trac
colorado jeep club member # 74
wojtizzlator is offline   Reply With Quote
Old 08-02-2007, 12:44 AM   #8
Jmila1901
Yup its worked out pretty good, Now that i have all the grounding taken care of my volt meter reads higher than it did before!!!!
Justin Mila
Old 08-02-2007, 08:10 AM   #9
mrboom
1995 XJ Cherokee
Nice Job, But next time please wear shoes.
My Jeep Hates Me..
95 Sport. 4.5 homebrew lift.. *Bastard Pack and loving it*
Everytime a Commander Roles off the Lot, a Cherokee Dies.
mrboom is offline   Reply With Quote
Old 08-02-2007, 10:33 AM   #10
XJK
The Guru of Nothing
XJK's Avatar
nice work, i will do this at a later date, saving it
oh and x2 on the shoes.
-Kyle
XJK is offline   Reply With Quote
Old 08-02-2007, 01:06 PM   #11
ButcherJones
1977 CJ5
Sweet write up....and pics....
Im looking forward to the posi's as well.
Im going to be doing mine tonight or tomorrow night....
Alternater, optima red top, starter, and new cables.....
ButcherJones is offline   Reply With Quote
Old 08-23-2007, 06:28 PM   #12
rocketman121
Bumping this up.
Ive got the negative cable disconnected from the battery but can not get the other end off the engine. Its like welded on or something. I tried using a screwdriver and BAH but no luck.
Could I just cut off the cable as close as possible to the bolt/stud and be done with it?
-87 XJ 4.0 5spd, 2"BB, 31" BFG ATs on 15x8 Eagle 058s, trimmed and doorless
-01 TJ 4cyl auto FT 3" lift 33" Goodyear AT/S & BFG muds herculined tub
rocketman121 is offline   Reply With Quote
Old 08-23-2007, 07:40 PM   #13
tangofox007
Originally Posted by rocketman121
Bumping this up.
Maybe you should remove the stud.
tangofox007 is offline   Reply With Quote
Old 08-23-2007, 09:29 PM   #14
Jmila1901
just cut it and rough up the surface a little bit
Justin Mila
Old 08-23-2007, 09:38 PM   #15
BrunoS
rocket man: use a special nut to get the stud off. it's bolted in place. as an alternative, snip the braided end, leave the lug, and attach your new cable to the stud with a new nut and washer on top of it.
Newly Painted! Emerald Green '96 XJ 4x4 4.0 HO 5-spd
3" Lift + 31" Tires / D35 TracLok / NP231
Drilled out Stock Airbox / Gauge Cluster Upgrade
Magnaflow Muffler / High-flo Cat / MSD Coil
BrunoS is offline   Reply With Quote
Glock Forum
