upgrading a closed loop coolant system - JeepForum.com
post #1 of 4 Old 10-13-2009, 11:09 AM Thread Starter
CTeunuch
hey,
im looking to buy an 89 2 door, with the closed system. the coolant system needs some work anyway, and while im in there i was thinking of going to an open style. as far as i understand this, it should be as easy as ditching the radiator and pressure bottle, then putting in a newer style radiator with a cap that has the correct pressure. anything im missing? recommendations for a good radiator? thanks for the help.
-patrick
Think Twice Garage
"Yeah, that might work, pass me the grinder..."
94ZJ AX15/HP44/8.8/5.13's/35'' MTZ's SOLD
99XJ 4.0/AW4/HP30/8.25 build coming soon...
CTeunuch is offline
post #2 of 4 Old 10-13-2009, 11:30 AM
TheNerd
TheNerd's Avatar
If you swap out the radiator, you will also need a coolant overflow bottle, a newer style ('92+ I think) heater control valve for the new piping, and will need to address the coolant temperature sensor (your sensor is currently in the radiator, where as the open systems use a different type sensor in the thermostat housing). Check the FAQ sticky... there are sever comprehensive articles on how to do this.
There are actually easier ways to to that as well that don't require all the new hardware (its all in the FAQ).
-2001 XJ Limited, 4.0L, NP231 w/ SYE, AW4, 4.5" Lift, 32" tires, 4.56's
-1987 XJ Pioneer, 4.0L, NP231 w/ SYE, NV3550, 4.5" lift, 4.10's, D44 rear
TheNerd is offline
post #3 of 4 Old 10-13-2009, 06:36 PM
oderalxjlaredo
I chose to do this swap with all new components. I covered it in this thread (with photos on the last page): http://www.jeepforum.com/forum/f11/p...estion-834546/
There are a number of threads and other webpages with good advice on how to do this. Use the search function! And yes, as TheNerd said, you can use your existing system with a few mods, but I chose to start from scratch since all my components were pretty old and beat up.
oderalxjlaredo is offline
post #4 of 4 Old 10-13-2009, 06:49 PM
tangofox007
The bad rap that the closed system gets is almost entirely the fault of the failure-prone pressure bottle. Unless you actually need a new radiator, I would suggest that you consider a metal pressure tank. I put one on my '88 a couple of years ago and have had no problem since.
tangofox007 is offline
closed loop mode temp Livewire94 XJ Cherokee Technical Forum 6 06-09-2010 11:06 PM
Adding coolant to a closed system... tgod XJ Cherokee Technical Forum 1 02-16-2008 01:05 PM
XJ Closed coolant system brycaroni17 XJ Cherokee Technical Forum 2 07-15-2007 12:37 PM
closed or open loop cygnus58 XJ Cherokee Technical Forum 4 07-05-2007 09:25 AM
thermostat change on closed system w/o draining all coolant? Digitalchaos XJ Cherokee Technical Forum 6 12-22-2005 01:55 AM
