Quantcast update on death wobble/shake at 55 to 60 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > update on death wobble/shake at 55 to 60
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineGR8TOPS Introduces the Exogate HD Tire CarrierThe Original 3/8" Ruffstuff Diff Cover!
Old 06-29-2008, 07:02 PM   #1
Walter Crovo
I modified my drag link where it connects to the axle, what a PIA. a few hours and 2 cobalt bits later the entire scope of the shake has been changed. Still there but to a much lesser degree. i will replace the drag link because the other end has some play. Every one of our xj's should get the mounting bolt and bushing mod done, my front end feels so much tighter. Use a 7/16x3" bolt and drill out the bushing to accomadate, you will be surprised at the results.
93 5 speed over 160k
99 5 speed over 85K
01 auto over 70k
99 auto over 90k
Walter Crovo is offline   Reply With Quote
Old 06-29-2008, 08:48 PM   #2
scuba413
Do you have any Pics of this Mod. I know the front end pretty good but cannot picture a draglink
scuba413 is offline   Reply With Quote
Old 06-29-2008, 09:05 PM   #3
Cruzin Illusion
Round Eyed XJ
Cruzin Illusion's Avatar
1987 XJ Cherokee
Usually if you have a vibration/shimmy at a certain speed and you can drive through it, it tends to be a balance problem. Death Wobble usually starts when hitting a bump or a uneven portion in the road and slowing down is one of the only things to stop/minimalize it. A vibration/shimmy accures at a certain speed often when running larger tires. Death Wobble is usually caused by worn/loose components in your suspension system or improper geometry when setting up a suspension system. Such as to much lift on a short arm lift. If the arms have such a downward angle because of to much lift (bigger coil springs than recommended or the addition of coil spacers) than there is no forward support on the front axle causing a shimmy. Another cause is not enough caster angle. This may not cause death wobble so much as having a hard time keeping your vehicle to go straight down the road. This is just a little information hoping to help you. You might want to take a look out the window at the speed you have posted to see if the tires start to shimmy at 55 and go away at 60. I think alot of time the term Death Wobble is misused.
CRUZIN ILLUSION
BUILT NOT BOUGHT
By Cruzin Illusion Customs
View the Cruzin Illusion Rig here:
View Cruzin Illusion's Rig
(OlllllllllllllO)
Rock Frog
CIC's Build Threads:
XJ Bolt on Tube Fenders / XJ-8 Grille (Round Headlight Grille) / THOR 4x4 Quarter Guard Install / XJ Custom Bumper with Swing Down TIre Carrier / Custom Width HP44 Build and Tech /Cruzin Illusions XJ Roll Cage Pics / Cruzin Illusion Tube Door Build
Cruzin Illusion is offline   Reply With Quote
Old 06-29-2008, 09:34 PM   #4
Walter Crovo
my mistakei meant track bar. death wobble, shimmy, shake=strg wheel goes nuts at certain speed, around 55 is the common area. cetain things like going up hill and turning thru a curve will set it off. any of us that have this issue know exactly what i mean. all the basic stuff has been done, balance, rotation, ck for bent wheels. i love my jeeps but this is definately a jeep thing. my 01 is just starting to shake in the same zone. both are stock, one is up country. i am going to do upper control arm bushings, i need to make the special tools or fork out the bucks from miller tools to get the factory stuff, i am open to suggestions on the tooling to do the job. burning, hack sawing and pounding are not an option for me.
99 5 speed over 85K
01 auto over 70k
99 auto over 90k
Glock Forum
