#1 | |
Up country vs. regular coils
I have a 96 XJ with the Up country suspension package. Does the up country suspension use different coils to achieve its lift?
If so, would it be better to keep my up country coils when I do my 2" BB and HD rear leaves or should I swap out the front coils for new stock units? I have already purchased new stock replacement front coils, but if they throw off my lift I might just sell them.
#2 |
What does your jeep measure from the center of the front hub to the bottom edge of the flare? Stock is 17.5" I think.
'99 Sport...Custom Front & Rear Bumpers, Rusty's Air Tube, Dynomax Exhaust, Hacked Fenders, Cut 'n Fold Rear Quarters, Durabak'ed Fenders-Rockers-Doors, OME 2" & 265/75R16 Kumho's, Silverstars w/ Upgraded Harness SOLD
#3 |
Well the beast is in the shop right now, but basically if the hub to flare measurement is greater than 17.5" then keep the springs, if its 17.5" or less I should be safe swaping springs because my front coils are sagging anyway?
#4 |
The up country is 1 inch over stock. You should be around 18.5 in the front and 18 in the back. Your new springs will be shorter if your current hasn't sagged. So you would have a 3" lift with a BB.
#5 |
True, but I've just never seen a separate part listed in quadratec for a front coil. I was just curious where the upcountry's sat after a few years of use.
#6 | |
Go Jeepin
My UpCountry coils have 91,000 miles and lots of 4x4 miles on them and have not sagged yet. The leaf springs are much more likely to sag than the coil springs.
. FOR SALE: Wide Track CJ-7 Dana 44 rear axle. PM me for details A Government big enough to give you everything you want, is a Government big enough to take from you
everything you have. The course of history shows that as a Government grows, Liberty decreases. |
#7 | |
i found this on another board posted in '04 UP COUNTRY SUSPENSION PARTS Part # Description Net ea. Total 52088363 Code GN front springs $31.69 $63.38 52089145 Code JJ rear springs 36.37 72.74 52037555 Rear spring isolators 6.90 13.80 52005645 Front jounce bumper spacers 7.01 14.02 52087675 Rear jounce bumper spacers 5.59 11.18 Part # Description Net ea. Total 5DL32MXW UpCountry Susp. Grp. sticker $13.48 $26.96 Prices subject to change..................(duh) I want to boost my 98ZJ 5.2 with these parts also. Want to add another 3/4" or so with some insulators. |
#8 |
#9 |
x3 with 139k. but my rears are sagging to non up-country height
#10 |
move to own thread
88' YJ/CJ 99 Two Door Cherokee DD Build thread:http://www.jeepforum.com/forum/f22/should-have-started-cj-build-1066682/ MASSKRAWLERS.COM Last edited by MA88XJDude; 10-19-2009 at 10:28 PM.. |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
