#1 | |
Up Country Option Rear Axle
does anyone know how the rear axle works on the up country suspension package on a '99? is it a locker or limited slip etc...?
1999 Jeep Cherokee Sport 4x4 4.0L (243ci.) w/ Automatic Transmission |
#2 |
It for sure has no locker. I am also almost positive it does not have limited slip unless its a D35.
What year? |
#3 |
1999, he said it in hte first post
1998 XJ-2" lift on 33's 1994 YJ, highlined, 31's (sold) |
#4 |
On my '01 the upcountry package included a Trac-Lok limited slip in the 8.25, I think it's the same for the '99.
#5 |
#6 |
It is the Trak Lok lsd and works pretty much like any other lsd. It uses clutch packs and requires an additive to be added to the pumpkin lubrication. You can purchase rebuild kits if yours no longer seems to work, however there are better choices available now (read Aussie Locker) which provide better locking performance than the Trak Lok does (when it works).
96 w/ 5spd, 4.10s w/ lsd, Bastard Packs, armor/ rack, BFGs & JK Blacks |
#7 |
what gear ratio is my '99 cherokee with a chrysler rear most likely to be?
#8 |
forum supporter
3:55....................
#9 |
XJ on 37's
Some bed time reading that will answer your next 3 questions...
![]() http://www.jeepforum.com/forum/f11/tech-faq-links-tsbs-89273/ Martin
1998 XJ on 37's.JK Rubi axles with chromo shafts and ctm's, 4:1 transfer case, etc etc etc.The Cherylkee.... 1998 Range Rover 4.6 HSE 2000 4.7 4WD WJ with a rebuilt motor. 4.3/700r4/new frame buildup (YJ).... http://www.jeepforum.com/forum/f12/swap-offically-underway-324622/ Years to gain the hands on experience, and offer it freely. Minutes to gain the knowledge from the internet, and quote it just as freely. Choose wisely! |
#10 |
![]() Tech/FAQ links and TSBs. Good answer , good answer , ... |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
