Quantcast Unofficial Mother of all Climate Control Issues Thread! - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Unofficial Mother of all Climate Control Issues Thread!
TJ 5.25" Speaker Adapters - NalinMFGTruck-Lite's New LED Headlamp Series4.25" 97-06 Jeep TJ Wrangler Lift Kit - NO SYE Needed
Old 12-22-2008, 03:04 AM   #1
keepishop
keepishop's Avatar
1989 XJ Cherokee
I've been seeing a lot of climate control issues lately, mainly the lack of heat, so I though it might be a good idea to get a Symptom/Solution kind of thing going. Maybe someday I'll have my first sticky here...
Problem: Cold air out vents on all heat settings
Solution: Confirmed Solution Needed! Possible Solution Below
http://www.jeepforum.com/forum/f11/heater-blows-cold-air-while-driving-just-warm-air-when-sitting-654680/
Problem: More heat wanted
Solution: Flush the heater core, possibly replace heater control valves and thermostat, reroute older cooling hoses to remove vacuum powered heater control valve.
http://www.jeepforum.com/forum/f11/heater-help-630448/
Problem: Fan only works on the highest setting.
Solution: Replace Blower Motor Resistor Pack
http://www.jeepforum.com/forum/f11/blower-motor-resistor-206575/
Problem: Blower Blows fuses, not air
http://www.jeepforum.com/forum/f11/heater-blower-1995-cherokee-617401/
Problem: Air only blows out of the defrost vents.
Solution: Check vaccum line running from the vaccum cannister in the front bumper, along the firewall, and to the intake manifold. They get brittle with age and crack in a million different places. Can be taped (duct tape, seriously), or a better solution is to just replace them with rubber hose, not plastic.
from XJ4oh
Problem: AC Compressor Squeals
Solution: Tighten serpentine belt, or replace AC belt, bearings, or whole compressor.
http://www.jeepforum.com/forum/f11/ac-belt-656729/
Problem: Engine runs too cool (~170F) for adequate heat
Solution: Place a chunk of cardboard behind the grill to block airflow and bring the temp up to about 210F. Remove some if it runs too hot. Replace thermostat.
Problem: No A/C on a renix (87-90) I6
Solution: Electrical diagnostics: http://autorepair.about.com/library/faqs/bl515f.htm If no electrical fault is found, the A/C must be serviced by someone with a license to handle the refrigerant (e.g. a shop, sorry).
Problem: Blinkers weak with blower on
Solution: Clean fuses of corrosion, clean ground on LH shock tower (FSM says the B3 splice leads there). Mostly fixed.
Always remember to burp your system before banging your head over aproblem!
keepishop is offline   Reply With Quote
Old 12-22-2008, 04:11 PM   #2
XJ4oh
1997 XJ Cherokee
Bump... this should help alot of people out. Thanks for taking the time to put that list together.
One more to add...
'97 XJ... 4.0 4x4 AW4.
2" budget boost w/t-case drop.
30x9.5 Kumho M/T's on 15x7 Cragar Soft 8's.
Intake, Ported TB, TB spacer, Super 40 Flowmaster.
Baja Aux. Lighting.
Green Jeep Club #185, Nowhere to Wheel Jeep Club member #1
XJ4oh is offline   Reply With Quote
Old 07-14-2010, 12:05 AM   #3
keepishop
keepishop's Avatar
1989 XJ Cherokee
Updated with renix A/C diagnostics for summer.
Current: Black 89 limited, dakota bastard pack, zj coils, 1.5" lift, open cooling swap, bronco 2 carrier, rad fan switch
Rest in Pieces: Red 1990 cherokee dana30/8.25 - v8 zj coils & s10 bastard pack 2.5" lift - 31x10.5r15 tires - v8 zj tierod
Originally Posted by talentjeep View Post
Bleed or Quit.
jf irc @ irc.freenode.net #jeepforum
Old 12-06-2011, 09:23 PM   #4
keepishop
keepishop's Avatar
1989 XJ Cherokee
Bumping for winter. (My heat is hotter than Hades!)
Bleed or Quit.
Old 12-06-2011, 10:24 PM   #5
bldeagle10
XJ Explorer
bldeagle10's Avatar
nomination for sticky, or posted in the tech/FAQ links and TSBs thread!
1999 XJ Cherokee SE 4.0 330k miles, DD, 2" spacers Chili Pepper Red
www.facebook.com/muldner
FS: 2000 XJ 4.0 ECU pm for details!
Build Thread:
http://www.expeditionportal.com/forum/threads/66115-Project-Brooke-1999-XJ?referrerid=17111
Originally Posted by egodfrey View Post
my diffs and unibody rails have more scrapes then an emo-girls arm
bldeagle10 is offline   Reply With Quote
Old 12-07-2011, 01:03 PM   #6
andrewmacc
Definitely will be back to this topic once the Jeep is out of the garage.
My heat is totally abysmal. Heater core flush first, thermostat second, I think.
Thanks!
'98 2dr/5spd Cherokee going on HP60/14b, 5.13:1, locked, 14" coilovers.
http://www.jeepforum.com/forum/f22/project-ton-ton-1-ton-cherokee-hp60-14b-1178116/
andrewmacc is offline   Reply With Quote
Old 12-07-2011, 02:43 PM   #7
keepishop
keepishop's Avatar
1989 XJ Cherokee
Working on a solution for the "no blinkers when using headlights and the heater" issue now. It's one that has bugged me on a few jeeps. Darn voltage drops.
Edit: Cleaning all the fuses and the ground just forward of the washer bottle (on a renix) on the left shock tower mostly fixed it. With the dome lights, headlights, and fogs on the blinkers work with the blower on all but the highest setting.
Bleed or Quit.
Glock Forum
