Unknown sensor, passenger side of headblock - JeepForum.com
post #1 of 10 Old 03-06-2013, 06:54 PM Thread Starter
nakosd
working on a 2000 cherokee, Il6
Pulled the headblock, and the cord that was plugged into the male end of this black clip broke off, oops
guy at the dealership called it a condenser, it regulated fuel content or something.
the black plastic part has a metal part that comes out and it is fastened to a bolt sticking out of the passenger side of the headblock.
i removed the bolt, its just a bolt with nothing attached.
i still don't know what its real name is, or whether its just some sort of improvised grounding strap.
the wire goes into a wiring harness encased in black tubing
nakosd is offline
post #2 of 10 Old 06-23-2013, 08:35 PM
STORMES
Ever find out ? I have the same thing
STORMES is offline
post #3 of 10 Old 06-24-2013, 07:30 AM
CCKen
CCKen's Avatar
Its called a "Coil Capacitor".
It's wired in parallel with the power wire from the ASD relay to the Coil Rail.
I've seen accounts where it was disconnected and the engine ran fine, but I suggest that you reinstall it properly. The German rocket scientists at Daimler Chrysler put it there for a reason.
Edit: It has nothing to do with fuel.
CCKen is offline
post #4 of 10 Old 06-24-2013, 09:32 AM
lazyxj
Sure can't find any mention of it in the 2000 FSM or the wiring diagrams.
Do you have any more information about it?
2001 Sport, 4" lift, 33 X 10.50 KOs, R.E. DB, R.E.-UCA, JKS-LCA, ACOS, 8.25-4.56-TruTrac, SYE, D-30 E-locker w/alloy shafts, Hidden M8000 winch, Vanco front and ZJ rear disc brakes, Lots of armor, Towing baseplate.
lazyxj is online now
post #5 of 10 Old 06-24-2013, 11:04 AM
CCKen
CCKen's Avatar
It's in the 2001 FSM wiring diagrams, and the 2001 parts catalog, part number 56041396AA. The 2000 parts catalog doesn't show it.
Edit:
The 2000 parts catalog lists a coil pack but doesn't show it.
I don't have a 2001 FSM and the 2000 FSM doesn't mention it.
CCKen is offline
post #6 of 10 Old 06-24-2013, 02:42 PM
lazyxj
Edit:
OK, found it in the 2001 XJ parts manual, it's a ignition noise suppression capacitor.
Strange there is no mention of it in the 2000 FSM. Searching XJ sites shows nothing, found it mentioned in WJ and TJ sites for post-2001 models.
Thanks for answering the question.
post #7 of 10 Old 06-24-2013, 06:11 PM
STORMES
Thanks for the info guys. I was searching everywhere. Jeep ran fine without it but would like to be on the safe side.
STORMES is offline
post #8 of 10 Old 06-29-2013, 02:47 PM
KF4SQB
1994 XJ Cherokee
If its an ignition noise suppressor, the engine will run fine without it, and will not be damaged. Its only purpose in life is to try to prevent engine ignition noise from getting in your stereo or a CB. If you're not having noise problems in the audio output of any electronic devices, you don't really need it.
4-wheeling: because football, basketball, baseball, and golf only require one ball!
Confidence: The feeling you get just before you fully understand the situation!
KF4SQB is offline
post #9 of 10 Old 06-29-2013, 03:53 PM
Paradise XJ
1988 MJ Comanche
Headblock ??
1990 XJ Laredo - White & Chrome
1988 MJ Pioneer - Metallic Green and Black
Paradise XJ is offline
post #10 of 10 Old 06-29-2013, 06:43 PM
CCKen
CCKen's Avatar
If the dog didn't stop to take a ***** he would have caught the rabbit.
CCKen is offline
