Unknowingly overheated..now ripping into the motor - Page 4 - JeepForum.com
post #46 of 64 Old 08-25-2013, 02:56 PM Thread Starter
Jeeperez
Originally Posted by AZ Jeff
I know you are replacing the engine, which is an easy way to solve your VERY big problem, but I must answer your question here, because someone else answered wrong.
Using one oversized piston with all others of "normal" size is not a problem. In fact, the factory used to do that quite often in the old days before the machining equipment could make very consistent bore diameters and piston sizes.
It was NOT uncommon at all to find engines straight from the factory with oversized bores on one or two cylinders. They would mark it with special punch marks on a certain spot on the block (described in the FSM) that would clue the technician working on the vehicle to the other-than-standard bore diameters. This was also done for main and rod bearing sizes as well.
It's rare for this to happen nowadays, since the machining equipment at the factories generates MUCH more consistent dimensional parts.
Thank you for this. Now I know!
Matt
Originally Posted by daverubino View Post
Sell your YJ???? Why would anyone do that. You dont sell YJ's you just keep them until they become parts heeps for your next one.
Jeeperez is offline
post #47 of 64 Old 08-26-2013, 06:43 AM
cbenez1
That sucks... But its not the first time I've seen water pump do that. Glad your up and running again. Enjoy
A nation that forgets it's defenders will itself be forgotten
01 Up Country 6.5 long arm
cbenez1 is offline
post #48 of 64 Old 08-26-2013, 10:43 AM Thread Starter
Jeeperez
Yeah it's quite the failure. Explains why my heat didn't work last winter! Workin now
Thanks!
Matt
Jeeperez is offline
post #49 of 64 Old 08-31-2013, 10:37 AM Thread Starter
Jeeperez
One more question. Looking back over my engine I seemed to have forgotten a vacuum line. Can anyone tell me where this goes?
Matt
Jeeperez is offline
post #50 of 64 Old 08-31-2013, 04:24 PM Thread Starter
Jeeperez
Bump
Anyone?
Matt
Jeeperez is offline
post #51 of 64 Old 08-31-2013, 04:40 PM
BassMasterCHS
1993 XJ Cherokee
For my 93, that's where my line for the fuel pressure regulator goes, as well as a line to the charcoal canister.
3 Inch lift, 30" BFG AT's, Walmart lights up front.
BassMasterCHS is offline
post #52 of 64 Old 08-31-2013, 06:02 PM Thread Starter
Jeeperez
Do you have a picture of where the line runs too?
Matt
Jeeperez is offline
post #53 of 64 Old 08-31-2013, 06:16 PM
BassMasterCHS
1993 XJ Cherokee
One sec, new POS owners won't let you upload from your phone.
post #54 of 64 Old 08-31-2013, 06:18 PM
BassMasterCHS
1993 XJ Cherokee
https://docs.google.com/file/d/0B-Q4...p=docslist_api
post #55 of 64 Old 08-31-2013, 06:27 PM Thread Starter
Jeeperez
Are you using the app? I'm able to upload via phone.
Also, the google doc needs permission to view
Matt
Jeeperez is offline
post #56 of 64 Old 08-31-2013, 06:34 PM
BassMasterCHS
1993 XJ Cherokee
Yeah, I'm using the JeepForum app on android. Just tried uploading from the computer and got the same message. Not sure how else to upload pics. Hopefully you are able to see it, I made it available to you.
post #57 of 64 Old 08-31-2013, 06:57 PM Thread Starter
Jeeperez
Got it thanks. Your engine is unbelievably clean
I don't ever remember taking off a hose like that from my old 4.0 ill have to take a closer look in the AM to see if I can pinpoint the connections. Do you have A/C?
Matt
Jeeperez is offline
post #58 of 64 Old 08-31-2013, 07:40 PM
BassMasterCHS
1993 XJ Cherokee
Haha, thanks. Probably because it only has 1,500 miles on it. Your set up will be pretty different than mine. Might want to wait for someone with a similar year to chime in.
And yes, I have A/C
post #59 of 64 Old 09-02-2013, 09:36 AM Thread Starter
Jeeperez
Anyone else want to chime in? Are the intakes from a non A/C model different from the A/C models?
Matt
Jeeperez is offline
post #60 of 64 Old 09-02-2013, 04:59 PM Thread Starter
Jeeperez
No one?
Matt
Jeeperez is offline
