Unknowingly overheated..now ripping into the motor - Page 3 - JeepForum.com
post #31 of 64 Old 08-17-2013, 07:20 PM Thread Starter
Jeeperez
Originally Posted by AZ Jeff
I will add one other comment--damage like I saw in your photos generally needs an oversized bore with a matching piston to properly correct the damage....
My question is.. Will one oversized piston and 5 standard pistons run smooth?
Matt
Originally Posted by daverubino View Post
Sell your YJ???? Why would anyone do that. You dont sell YJ's you just keep them until they become parts heeps for your next one.
Jeeperez is offline
post #32 of 64 Old 08-17-2013, 07:28 PM
BassMasterCHS
1993 XJ Cherokee
I gave wrong info, sorry. You can replace just one piston.
3 Inch lift, 30" BFG AT's, Walmart lights up front.
BassMasterCHS is offline
post #33 of 64 Old 08-17-2013, 07:59 PM Thread Starter
Jeeperez
Would it be easier to just throw in a new motor?
I'm guessing to keep the current motor I'd have to make all 6 oversized..?
Matt
Jeeperez is offline
post #34 of 64 Old 08-17-2013, 08:06 PM
BassMasterCHS
1993 XJ Cherokee
With this kind of failure, yes it would be. Call around to a bunch of shops on Monday and get some prices.
post #35 of 64 Old 08-20-2013, 08:25 AM Thread Starter
Jeeperez
Found a motor from a local shop. Going to look at it tonight. 137,000 miles out of a 98. Guess it ran beautiful. Wants $200
Matt
Jeeperez is offline
post #36 of 64 Old 08-20-2013, 09:00 AM
cbenez1
$200 for a good running 4.0 is a bargain. If you can hear it run. If not it's a crapshoot unless they offer a warranty. I sell them for $500 but I leave them in the vehicle so buyers can hear/see it run before purchase.
A nation that forgets it's defenders will itself be forgotten
01 Up Country 6.5 long arm
cbenez1 is offline
post #37 of 64 Old 08-20-2013, 09:03 AM
cbenez1
On that note I have a 103k 4.0 in a 96 for sale but your a bit far away. Good luck with your project.
cbenez1 is offline
post #38 of 64 Old 08-20-2013, 05:29 PM Thread Starter
Jeeperez
Well 200 is worth the motor. I'm sure it'll run good, he was willing to install it for an extra 200 guaranteed to work. But we will see this weekend, it looks to be in good shape
Matt
Jeeperez is offline
post #39 of 64 Old 08-23-2013, 10:22 AM
cbenez1
For an extra $200 I'd have let them install it and saved myself the hassle. Hope it works out for ya.
cbenez1 is offline
post #40 of 64 Old 08-24-2013, 08:38 AM
poppyseed
^agreed
poppyseed is offline
post #41 of 64 Old 08-24-2013, 06:48 PM
AZ Jeff
2014 JK Wrangler
I know you are replacing the engine, which is an easy way to solve your VERY big problem, but I must answer your question here, because someone else answered wrong.
Using one oversized piston with all others of "normal" size is not a problem. In fact, the factory used to do that quite often in the old days before the machining equipment could make very consistent bore diameters and piston sizes.
It was NOT uncommon at all to find engines straight from the factory with oversized bores on one or two cylinders. They would mark it with special punch marks on a certain spot on the block (described in the FSM) that would clue the technician working on the vehicle to the other-than-standard bore diameters. This was also done for main and rod bearing sizes as well.
It's rare for this to happen nowadays, since the machining equipment at the factories generates MUCH more consistent dimensional parts.
AZ-Jeff
I don't own an XJ any longer, but I still think they are the best of all the Jeep products ever made. My XJ was my favorite vehicle in my 50+ years of driving.
So...I stick around and give advice.
AZ Jeff is offline
post #42 of 64 Old 08-24-2013, 08:06 PM
cbenez1
^See above post for correct facts.^
cbenez1 is offline
post #43 of 64 Old 08-25-2013, 07:17 AM
Kalali
$200 for the engine and $200 for the R&R, with guarantee, is unheard of. Its a no brainer...Let us know how you make out.
Kalali is offline
post #44 of 64 Old 08-25-2013, 02:52 PM Thread Starter
Jeeperez
Ok guys, did the swap this weekend. Had to swap over most of the front of the motor because the engine I bought was not an A/C model. Also the flywheel had to be swapped out because it was not matching at all
All in all it's a success! The new motor purrs like a kitten, has no leaks or ticks. Took me longer than it should have but I'm happy it's done.
Matt
Jeeperez is offline
post #45 of 64 Old 08-25-2013, 02:55 PM Thread Starter
Jeeperez
Also figured out why my last engine overheated...
Because my water pump was almost non existant!
Matt
Jeeperez is offline
