Quantcast Unitbearing slaughter - Page 6 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Unitbearing slaughter
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineDISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-GR8TOPS Introduces the Exogate HD Tire Carrier
Old 09-10-2008, 09:23 PM   #76
HeepToJeep
1982 CJ8
The only reason Chrysler switched to ballbearings was because they're cheaper, rollerbearings are FAR superior in every way. Most people can get away with switching the hub, rotor and caliper but a couple have reported having to switch the knuckle as well. My approach would be taking my knuckle with me when I went to get my donor parts and compare the caliper mounting, if the old style caliper lined up with my knuckle then I would only get the hub, rotor and caliper...if it didn't, yank the knuckles as well. The difference in rotors is the center hole size and overall thickness.
Wm
HeepToJeep is offline   Reply With Quote
Old 09-10-2008, 09:39 PM   #77
XJLI
1993 XJ Cherokee
hmmm..
looks like i may have an upgrade in order..
Factory Four Link
XJLI is offline   Reply With Quote
Old 09-10-2008, 09:41 PM   #78
kg4kzv
1995 XJ Cherokee
Originally Posted by HeepToJeep View Post
The only reason Chrysler switched to ballbearings was because they're cheaper, rollerbearings are FAR superior in every way. Most people can get away with switching the hub, rotor and caliper but a couple have reported having to switch the knuckle as well. My approach would be taking my knuckle with me when I went to get my donor parts and compare the caliper mounting, if the old style caliper lined up with my knuckle then I would only get the hub, roto and caliper...if it didn't, yank the knuckles as well. The difference in rotors is the center hole size and overall thickness.
Wm
I may have the parts needed all ready. I have an 86 XJ parts Jeep and a 89 that I don't know what I'm going to do with yet. So if I need to swap knuckles that is no biggie.
Chris.
95 Cherokee SE 4.0, 5-Spd, 8.25;
6.5" Rusty's Lift, Atlas II Rims, 35x12.5x15 Wild Country,Rusty's Tube Bumper, Wilderness Rack
Rock Sliders, K&N Panel Air filter, PSC steering box,
I-ROK reinforcement kit, ORO U-TURN steering kit,Conversion Headlights/Silverstars And too much $$$
kg4kzv is offline   Reply With Quote
Old 09-11-2008, 08:30 PM   #79
Bryson
Wm
I've heard from a couple people who've done the swap, that the only thing needed was the early style rotor. Thats from people with early going to late, as well as late going to early (so to speak). There are different PN's between the early and late model D30 knuckles, but whether or not that difference is in anyway related to the caliper is unclear.
I'll be doing the swap eventually, but would like to do a brake upgrade at the same time (wilwood calipers and 12" rotor FTW). I will be selling the brake kit eventually as well
99 chilipepper red XJ: Race car tow rig. Turbo project in the works.
Head of Core production - www.CortekSystems.com
Owner of Boostwerks.com
Website in development.
Bryson is offline   Reply With Quote
Glock Forum
