#16 | ||
Man In Black
![]() Join Date: Oct 2003
-Marc- Sweet Pea 1998 - XJ http://www.grobe.us/Jeep - JeepForum Rules - Become a Premium Member or Vendor For Sale: (4) AR 767-5766 Wheels (used) 15x7, 5x4.5, 4.5BS - for local pickup in the Chicago-area |
#17 |
I had some cheap eBay specials do that. As soon as I took off the calipers and rotors, they just fell apart onto the ground.
Now I only use the Timkens and also carry spare outers. |
#18 | |
AZ-Jeff 1992 XJ 2" lift -- RIP 2000 XJ 3" lift -- Australian Ford Big Brakes up front, rock rails, ZJ rear discs (with WORKING parking brake), C4x4 rear bumper/tire carrier, Hella H4 headlights, IPF driving lights, OEM skid plates, OME springs/shocks, JKS LCA's, JKS Sway Bar links. |
#19 |
Some of you might be wondering why the Jeep bearings fail in the first place. It's because all of the ones that I've seen utilize a ball bearing design. Ball bearings simply do not have a high thrust load capability.
Angled roller bearings however, are much more common in a wheel bearing design because they are much more effective at controlling high thrust loads in addition to normal radial load. I'm not sure if the timkens are roller or ball?
99 chilipepper red XJ: Race car tow rig. Turbo project in the works. Head of Core production - www.CortekSystems.com Owner of Boostwerks.com Website in development. |
#20 |
very good point for sure
but they were also designed to run 195/75-15 tires too 35s are much bigger adding much stress to a "weak" design. weak for 35s but good enough for 195s |
#21 | |
Ball bearings + wheel bearing application = I also think this is one of the main causes of front end vibrations as well in almost every stock D30 application.
#22 | |
44:4.56, Alloy USA chomos, Yukon Superjoints, Lockrite / 9":4.56, Detroit Caged/Skided xj on 37s with some other goodies -Sinking Creek 4wd Association Blacksburg, VA www.sc4wda.org.vt.edu My 44 Build: http://www.jeepforum.com/forum/f11/my-wagoneer-44-build-start-finish-466573/ Last edited by shmoken875; 12-23-2007 at 11:42 PM.. |
#23 | |
I was there that same weekend and saw him about 4 hours prior on the trail where he broke. We had a fellow member that same weekend break his locker and we had to remove the shaft to allow the locker to spin freely to get back to camp. We were about 50 feet from the campsite and it let loose. They were only driving about 5MPH and it broke the knuckle; I can only imagine what it looked like letting loose at 60... ![]() ![]() As stated above, DO NOT DRIVE WITHOUT A SHAFT IN IT! |
#24 |
I have driven once without the shaft in... and had to wheel it pretty hard to get out of where I broke the shaft.
and then drove 20miles home... avg of 45+ mph wow I feel lucky... glad I carry spares, both hubs and axles |
#25 | |
97 xj 44 front, detroit, alloyed 60 rear, detroit, 35 spline alloyed 35" beadlocked km2's 3" midarmed more bells and whistles than you can shake a stick at |
#26 |
your 6th hub..you might want to look into something a little stronger..and yeah taking the shaft out is a killer..luckly when it happened to me my brakes kept my wheel from falling off
big lift, sick tires, awsome accessories, alot of custom work. my jeep won the war, your honda mows my lawn |
#27 | |
1999 Cherokee Classic Deep Amethyst 60,000 miles Mods: Dynomax Cat-back OME CS035RA Heavy Load Rear Leafs (~3.25") RE 1334 Front Spacers (~2.5") P.O.R.C. HD SYE 30x9.5 General Grabber AT2s B&M SuperCooler 70255 and Temp Guage |
#28 |
Forum God
he was asking what the kid was doing, not what you should do in general
Though I wheel through the valley of the shadow of death,
I will fear no evil: For thou lockers are with me; Thy lift and thy tires, they comfort me. Thou preparest a spotter before me in the presence of mine obstacles; |
#29 |
yea..i was doing it to whatever spec was. im building a 44 front right now so im not worried about it, and that will be my "stronger" option. ive got hubs from advance with a lifetime warranty so i really dont even worry about it
[CENTER]1995 fire red XJ, new 4.0, ARB safari snorkel, sye, front DS, aussie locked 8.8 5:13s 38 SXs, trussed/locked 44 front, hydro assist, DOM steering/COLOR] YJ. 91 body, body off resto, crate chevy 350, 700r tranny, 2 inch springs, SOA, ford 9 rear, dana 44 front, both detroits, cage, 4:88s, and 36X14.50s. strictly street queen |
#30 | |
http://www.partsamerica.com/ProductDetail.aspx?MfrCode=SKF&MfrPartNumber=JLM60 3048F&PartType=184&PTSet=A |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
