Unibody design = Designed obsolescence? - JeepForum.com
post #1 of 3 Old 10-09-2003, 04:47 PM Thread Starter
jmbrowning
jmbrowning's Avatar
The Missus has it in her mind to pick up an XJ for mod off-roading and backup duty to the Subi Outback for daily driver use. XJ's are pretty common and pretty cheap around here.
I have a concern about the unibody design though. Unlike the tub on frame designs which seem to last forever, until the tub gets replaced, the unibody seems to be susceptible to fatigue and flexing.
How long does the unibody last before it flexes so much that the doors and hatch don't close anymore? Should the Wife get a new XJ and get the chassis reinforced before any lifting or off-roading occurs?
Admittedly, being as inexpensive as they are, could just part out the rubber XJ and slap the saved parts in another one.
Quis custodiet ipsos custodes?
jmbrowning is offline
post #2 of 3 Old 10-09-2003, 05:12 PM
JTruel
If you are worried, do what drag racers do
Build a set of longitudinal support braces (subframe connectors) and weld them in... Cherokees already have a similar thing, but extra insurance wouldn't hurt... and unibodies hold up fairly well UNTIL they get wrecked. I have a 63 falcon and its a unibody... so they can last
2000 XJ Classic
2005 LJ
JTruel is offline
post #3 of 3 Old 10-09-2003, 05:15 PM
cheesycook
Accident Prone Bonehead
cheesycook's Avatar
An XJ is actually Uniframe so it has some reinforcement. I don't know how long they last, unless you are doing serious flexing it shouldn't be a problem. Body stiffiners are a good idea just in case. I have been looking for something myself.
98 TJ 4.0 Stick 30 Lock-Right/44 True-Track,4.56. Fire RED. Optima Red top. 3" Full Traction lift, Cragar 352 Street locks w/3.75 BS. 32" BFG AT's. Sailcloth top.
tubular fenders. AtoZ Fab rockers and front and rear bumpers. TBT sportsbar and rear spreader. VDP 6 speaker bar. 2K Intake Manifold. Tuffy Speaker lock boxes. Power inverter. Cobra CB. Magellan GPS. Bed lined tub. 3core HD radiator. Olds airbox with Hummer snokle. Besttop seat covers with heaters. All running lights LED.Steering and oil pan skids. Mile Marker PE8000 winch. Currie Anti-Rock. Olympic trunk. Tuffy Console....and Buddha on the winch. :) And a child seat stained with mud.
Hermiston, ORL
, because I don't have a clue, but Stu does!
cheesycook is offline
What IDIOT designed the coolant drain? BoxOnRox XJ Cherokee Technical Forum 10 08-10-2007 09:21 AM
Bendix-designed ABS system, dangerous? timjanssen XJ Cherokee Technical Forum 15 08-19-2006 02:15 PM
unibody XJ StokedXJ11 XJ Cherokee Technical Forum 12 09-06-2005 09:31 AM
roof rack designed Timmy.o.tool XJ Cherokee Technical Forum 11 11-26-2004 09:24 PM
