Uni strap to u-bolt upgrade done - Page 2 - JeepForum.com
post #16 of 22 Old 01-09-2006, 04:55 PM
Rock Kustoms
Rock Kustoms's Avatar
i have those same staps in my 44's, never had an issue with them, beatin the piss outta it
Rock Kustoms is offline
post #17 of 22 Old 01-09-2006, 06:04 PM
bassicrob
bassicrob's Avatar
I was looking into this sometime back when I managed to strip the head off one the bolts securing the strap. I bought a number of u-bolts from the HELP! section and couldn't get enough clearance at the rear of the yoke. Everything I found online regarding this 'mod' was for a D35 or D44. Were the yokes different with the 27 and 29 spline 8.25?? Would've saved me some bucks. I ended up replacing the yoke. :
J_ep '93 XJ Country w/ RE 3.5", OME shocks, 31x10.5 BFG AT/KO's on AR-767s, TW SYE and DS for NP-242 TC, XD9000i, K&N Cone, Flowmaster Delta 40
Proud Survivor of a Rollover!! :) Flip & Roll Club Member #2
Daily Driver: 2006 Volvo S40
bassicrob is offline
post #18 of 22 Old 01-09-2006, 09:01 PM Thread Starter
MSHarnett
Broke Bogger
MSHarnett's Avatar
Thats weird? I only saw 2 diffrent sizes, maybe my HELP section blows, hahah. But anyway, I didn't have any issues with clearance though. You can see in the pics there I had more then enough room to put the nuts on. Were your u-bolts extra long or something? And I think the 27 and 29 have identical yoke part#s.
Matt
MSHarnett is offline
post #19 of 22 Old 01-10-2006, 06:41 PM
bassicrob
bassicrob's Avatar
missing that first step must've been my problem
post #20 of 22 Old 01-11-2006, 06:20 PM Thread Starter
MSHarnett
Broke Bogger
MSHarnett's Avatar
ah That is key
Matt
post #21 of 22 Old 05-03-2013, 07:49 AM
Grand Fan 4eva
I know this is pretty old... Has anyone else done this since? Yesterday I picked up a pair of u-bolts to use on my '00 8.25 (neapco 1-0089) and they fit the u-joint like a glove, but they look too narrow to fit the yoke properly. In other words, the U is too tight, and the ends are too close together to go into the holes in the yoke unless I bend the u bolts further apart or drill over sized holes in the yoke. Anybody have this problem?
'97 XJ ~5" / 33 trxus / RK 3-link / FOA 12" CO's
'91 MJ
'68 M715
'98 5.9 Limited
Grand Fan 4eva is offline
post #22 of 22 Old 07-06-2013, 03:28 PM
stevemongr
Try this from IronRock;
http://www.ironrockoffroad.com/Merch...tegory_Code=UP
stevemongr is offline
U-bolt strap torque specs? mh89xj XJ Cherokee Technical Forum 7 01-28-2010 06:49 AM
U-joint strap bolt size/thread underpowered XJ Cherokee Technical Forum 0 12-23-2009 11:10 PM
Broke u joint strap bolt in yoke! Disaster1126 XJ Cherokee Technical Forum 6 05-01-2009 06:51 AM
Fuel rail and injector upgrade? Renix vacuum upgrade? HeepToJeep XJ Cherokee Technical Forum 4 04-20-2008 08:06 PM
Damaged recovery strap - light-duty tow strap? mikejwil XJ Cherokee Technical Forum 2 06-28-2005 02:03 PM
