Uneven steering resistance - JeepForum.com
post #1 of 3 Old 05-12-2007, 10:57 PM Thread Starter
josephmartins
Long-time Jeep Nut
josephmartins's Avatar
A couple days ago my steering began acting up. Hot or cold, turning left or right, I can feel the resistance in the steering wheel increase and decrease as I turn it. As I begin turning the wheel it'll have some resistance, then it eases up, and then it increases again.
The situation seems to have worsened over the past couple of days. The fluctuation in the resistance is more dramatic and abrupt. Pump seems fine and fluid level is fine. Doesn't seem to be any play in the components. I jacked the front up and had someone turn near-lock to near-lock repeatedly and could not identify any obvious problems.
I thought it might be my stabilizer but I installed a brand new one not 10 months ago. I suppose it's still possible.
When I searched "steering problem", the following post described a similar problem:
http://www.jeepforum.com/forum/f11/steering-problem-104399/
And someone mentioned the steering shaft u-joints binding. Can anyone else confirm if that might cause the type of problem I have described? Seems plausible, but had no time to verify that for myself before it got dark. I drove 130 miles home tonight hoping it wasn't something worse.
Kind regards,
Joe Martins
Milford, NH
12 Wrangler Sahara JK8 conversion, <10 miles (FOR SALE, $56,700)
01 WJ Limited, 4.7, 247, black on black, 157k miles (sold)
96 XJ Classic, 4.0, 242, black on grey, 267k miles (sold)
00 XJ Sport, 4.0, 242, fern green on grey, 76k miles (sold)
90 XJ Wagoneer, 4.0, 242, burgundy on tan, unknown mileage (sold)
97 ZJ Limited, 5.2, 249, black on black, 138k miles (wrecked 12/15/05)
98 ZJ Limited, 5.2, 249, burgundy on black, 197k miles (sold)
josephmartins is offline
post #2 of 3 Old 05-13-2007, 07:55 AM
AZ Jeff
2014 JK Wrangler
Lift the front end up, to get the weight off of everything. Turn the steering wheel WITHOUT THE ENGINE ON. Do you still get irregular steering resistance?
AZ-Jeff
I don't own an XJ any longer, but I still think they are the best of all the Jeep products ever made. My XJ was my favorite vehicle in my 50+ years of driving.
So...I stick around and give advice.
AZ Jeff is offline
post #3 of 3 Old 05-13-2007, 04:51 PM Thread Starter
josephmartins
Long-time Jeep Nut
Unfortunately, yes. Even with the engine off and vehicle off the ground.
Kind regards,
Joe Martins
Milford, NH
Fan Clutch..........No resistance when hot?? Swiss XJ Cherokee Technical Forum 11 07-23-2008 12:27 PM
steering stabilizer increase resistance ChipsXJ XJ Cherokee Technical Forum 9 05-05-2007 05:50 PM
what controls the resistance in steering? ChipsXJ XJ Cherokee Technical Forum 14 10-11-2006 11:28 AM
ohm resistance for injectors? BackDraft XJ Cherokee Technical Forum 8 03-13-2005 12:15 PM
Steering resistance while turning XJ_Eric XJ Cherokee Technical Forum 4 02-24-2004 11:04 AM
