Underhood engine compartment light Mod - Page 2 - JeepForum.com
post #16 of 21 Old 08-24-2012, 12:13 PM
robinz
1990 XJ Cherokee
Originally Posted by Azzy View Post
As long as the housing and LEDS are up to, it should be OK. So, if you slam on the brakes, does it blink?
The answer to this is the same for "when you close the fridge door, does the light go out" question. Thanks again Azzy for your exemplary customer service for my recent purchase of your gauge kit.
Originally Posted by haolepinoy View Post
...but with a regular, manual flip switch rather than the mercury deal.
I'm presently doing similar. I had to pull my stock light because of my MAC surge tank and needed a replacement. The mercury switch is a novel ideal but I am using a lamp switch to control. I ordered these lights from a Chinese eBay seller last week and should have installed within a couple of weeks;
http://tinyurl.com/8umneqe
1990 XJ 4.0L I6
robinz is offline
post #17 of 21 Old 08-24-2012, 03:28 PM
cpttuna
Just another idea. Get an old tractor light bulb. Cut a clorux bottle so that the bulb will fit in the top part(keep the handle) after you wire it and have run the wires through the top and insured it works, silicone the light in place. You can either use battery clamps and hook it to the battery or a plug and use the cigar lighter socket for power.
cpttuna is offline
post #18 of 21 Old 09-01-2012, 10:34 PM
robinz
1990 XJ Cherokee
Originally Posted by robinz View Post
... I ordered these lights from a Chinese eBay seller last week and should have installed within a couple of weeks; http://tinyurl.com/8umneqe
Installed the light. I mounted it on a bracket so that it would clear anything in the engine bay. Works pretty good;
1990 XJ 4.0L I6
robinz is offline
post #19 of 21 Old 09-02-2012, 03:14 AM
DaddySS
Very nice and good thinking!
DaddySS is offline
post #20 of 21 Old 09-02-2012, 03:38 AM
MattBillyTayloe
Another project added to the list, this is a good mod. My underhood light is fried. Started smoking one night and I never hooked it up again.
MattBillyTayloe is offline
post #21 of 21 Old 07-13-2013, 10:18 AM
1999xjguy
My light was broken, thinking about the LED upgrade, now a year later, how are your LED's holding up? Thanks for your time.
1999xjguy is offline
Underhood engine compartment light Scorer75 XJ Cherokee Technical Forum 5 02-07-2012 10:23 AM
question regarding engine compartment light Kleber XJ Cherokee Technical Forum 2 01-30-2011 06:24 AM
Underhood light suddenly works after 2 years saycheese XJ Cherokee Technical Forum 13 12-06-2009 09:39 PM
Engine compartment very hot zman4 XJ Cherokee Technical Forum 12 05-28-2009 07:35 AM
underhood light IVIaxpower XJ Cherokee Technical Forum 14 09-13-2005 01:08 PM
