Under hood fuses - JeepForum.com
post #1 of 7 Old 04-11-2008, 01:36 PM Thread Starter
jcrowley
jcrowley's Avatar
1997 XJ Cherokee
Under hood fuses
does anyone have a listing of the fuses and relays that are under the hood, on the passenger side of the engine?
also, my haynes manual doesn't have anything at all for the wiring of the rear window defroster. does anyone have a schematic for this as well?
both are for 1997 Cherokee Sport, 4X4 Inline 6.
thanks for the help.
97 Cherokee Sport
jcrowley is offline
post #2 of 7 Old 04-12-2008, 12:30 PM
mickc9129
under hood relays
when you lift the lid off the relay box look on the underside. There's usually a schematic there of the relays and fuses within it. You'll note there's a 40 amp fuse in there for the rear window. That might be the problem.
mickc9129 is offline
post #3 of 7 Old 04-12-2008, 02:35 PM
mickc9129
defogger
There's also a 25 amp fuse beneath the instrument panel to the left of the steering column for window defogger.
post #4 of 7 Old 04-13-2008, 02:36 AM
posterChild
From the FAQ Sticky:
http://www.jeepforum.com/forum/f11/fuse-diagram-2000-xjs-33820/
It's a 2000, but it should help. I recently experienced the fuse box telling me to see the owners manual and the owner's manual telling me to see the fuse box dilemma.
posterChild
posterChild is offline
post #5 of 7 Old 04-13-2008, 05:58 AM Thread Starter
jcrowley
jcrowley's Avatar
1997 XJ Cherokee
mickc9129, thanks for the info. i didn't know about the fuse under the instrument panel. as far as the relay box, you are right, it does list the fuses and relays. however, there is a smaller section of fuses that aren't listed on the relay box cover. these are the fuses that i'm looking up information for. in particular, there's a 15 amp fuse there that blows occasionally that i don't know what it services.
thanks for the quick help.
97 Cherokee Sport
jcrowley is offline
post #6 of 7 Old 04-13-2008, 06:00 AM Thread Starter
jcrowley
jcrowley's Avatar
1997 XJ Cherokee
posterChild, i sortof ran into the same thing with my manual. the thing is, my jeep was broken into; one of the items stolen was my FSM from the glove compartment. so...i lost my "map" of the fuses and relays. do you have any info for the fuse panel in the engine compartment?
thanks.
97 Cherokee Sport
jcrowley is offline
post #7 of 7 Old 04-13-2008, 01:08 PM
mickc9129
under hood fuses
My '91 cherokee manual lists 3 15 amp fuses under the hood as follows:
Ignition11)
Back up lamps, shift selector,aux. cooling fan coil, a/c relay coil and speed control.
Auxiliary lamps: (12)
Fog lamps and underhood lamps
Hazard lamps15)
Hazard flasher and brake switch
You might pull that fuse out that keeps breaking and check to see if any of the above items isn't working.
Your thoughts on hood vents/ hood louvers?!?!?! LCFRJEEP XJ Cherokee Technical Forum 53 04-07-2010 08:11 AM
Hood Latch Problem!!! Hood won't open cherokeeKID XJ Cherokee Technical Forum 2 11-07-2009 09:37 AM
Fuses? dee41066 XJ/MJ Cherokee Non-Technical Forum 2 07-18-2008 05:41 PM
Hood release cable broken...any ideas to open hood? jeeps4life XJ Cherokee Technical Forum 6 05-16-2007 12:16 PM
Help with fuses aaron_mtn XJ Cherokee Technical Forum 6 08-03-2004 01:34 PM
