U Joints and Unit Bearing - JeepForum.com
post #1 of 4 Old 12-27-2012, 11:39 AM Thread Starter
jlsalani
I have some weird sounds coming from the pass side (up at the front wheel). Assuming it is either the axle u joint or the unit bearing... I may just replace both since the vehicle is 12 years old. Are the drive shaft u joints and the axle u joints the same?? was looking at this one
http://www.quadratec.com/products/52302_101.htm
is this the correct one for the axle?? Also the cost of the unit bearing varies like crazy, saw one for $250 and then all the way down to $40ish.... there is one on the Quadratec
http://www.quadratec.com/products/52417_05.htm
what do you guys think?
jlsalani is offline
post #2 of 4 Old 12-27-2012, 05:18 PM
xjfever
xjfever's Avatar
1995 XJ Cherokee
What model is your axle? And if it is an older one do you have ABS?
xjfever is offline
post #3 of 4 Old 12-28-2012, 06:19 AM Thread Starter
jlsalani
it is a Dana 30 and as far as I know it does not have ABS. The Cherokee is a 2000
jlsalani is offline
post #4 of 4 Old 12-28-2012, 05:24 PM
xjfever
xjfever's Avatar
1995 XJ Cherokee
For a 2000 model dana 30 you will need the 297 u-joints, the 260's came in the older pre '95 models without ABS.
xjfever is offline
