U joint, tie rod end, etc. problems, with video. Please help - JeepForum.com
post #1 of 4 Old 03-31-2014, 09:00 PM Thread Starter
YeOlCherokee
So below is a video of one of my 1998 Cherokee 4.0 Sport 4x4 100% stock - the front end.
This jeep has death wobble, bad. Mostly only between 60-70 mph.
I know i 100% need front tires and an alignment, but there are some things i need to fix. There is clunking/banging when turning in reverse or uneven ground at low speeds, and there is lots of slack in the steering wheel.
I got underneath, shook some stuff around, and I found 2 loose TRE's, a drag link that is tight, but clanks when tapped my hand, and a loose axle U-Joint. Please watch this short video, and put your sound up to hear the sounds. Give any input that you can (What I need to fix, what is normal, what exact parts i might need, etc.) - note - I do zero offroading, so i a just looking for the cheapest, yet effective fix... I am not looking to cut corners, but am not looking to upgrade to parts from a zj or rugged ridge, anything like that
https://www.youtube.com/watch?v=PzlOKnxiR0w
Im sorry, i do not know how to embed a video, here is the link
YeOlCherokee is offline
post #2 of 4 Old 04-01-2014, 11:24 AM
justanotherjpr
The direction you are moving those tie rod ends is within their range of travel. You need to be testing for them moving left-right and not twisting them. The best way to do this is to have someone turn the wheel back and forth quickly from one end of the play to the other.
So do you actually hear your thoughts in your head or is it just sort of a dull roar before you smash your face into your keyboard and just submit whatever dumb **** ended up on the page?
justanotherjpr is offline
post #3 of 4 Old 04-01-2014, 01:22 PM
Timo_90xj
Timo_90xj's Avatar
What you did there in the video is not going to reveal you anything being wrong or right. You cannot create large enough forces with your bare hands to get anything to show up - unless things are very seriously worn.
As mentioned above, have a friend rotate the steering wheel left-right steadily, and fairly quickly with the engine shut off. What you need to do is go under the front and start looking, and feeling the following things with your fingers:
1. Steering box/ and sector shaft for play.
2. All TREs for play (you're looking at up/down play, NOT if the TRE rotates)
3. Is the trackbar frameside TRE loose/ worn/ does it have play
4. Trackbar axleside bushing for play, and if the mounting bolt itself moves left-right (this is a sign of wallowed-out mounting hole, which is fairly common)
After you're done with this, then also check UCA and LCA bushings for wear. Place a crowbar between the CA pocket and end of CA, and pry in such a way that you're trying to move the CA front or back. There should not be too much movement front or back. Then try twisting (rotate) the CAs in similar fashion. Look for excessive play, and cracks on the bushings.
Any play on any of the mentioned items can cause DW. DW can also be caused by bad shocks, unbalanced tires (have you dropped a weight?), worn unit bearings (you'd hear it), incorrect caster angle, incorrect toe-in adjustment.
***Under construction***
Timo_90xj is offline
post #4 of 4 Old 04-01-2014, 02:30 PM
93gc40
So what Timo is saying is.... If it connects to the axle in anyway it could be bad and causing the death wobble.... Do the diagnosis, BEFORE buying any parts. If you think a part is bad replace it. Chances are most of that stuff is factory.... Most of it is well beyond it's designed service life anyway.
96 XJ 4.0 / 231 / 3.5" JY Lift/ 31" BFG /.....
93 VT1100 - Harley killer.
97 ZJ 4.0 / 242 / Stock
93 ZJ 4.0 / 2"BB / Wranglers / RIP-Gone but not forgotten.
If it aint dirty, it aint a JEEP, it's just a SUV.
93gc40 is offline
