u-joint jumped ship today ... - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ Cherokee Technical Forum > u-joint jumped ship today ...
SPARTAN LOCKERS are on sale BIG TIME at ROCKRIDGE 4WD!ZONE 4.25" combo lift for TJ available at Rockridge4wSpartan Locker 1 day sale This Friday only!
Unread 08-13-2014, 04:40 PM   #1
skyway0018746
So after two months replacing just about everything on the front axle to solve my steering issue I replaced the u-joints on sunday and have been driving it since . Today on a trip around town I hear a noise like a nut and washer just fell off. I wasn't too far from home so I just drove home. Looked at everything before seeing the cap on the u-joint was missing!!! Now for the fun stuff. I have lock out hubs so the shafts aren't turning and I never put it in 4wd with rhe new u-joints . Just got my spair ones in the mail today looks like I'm using one already .
7" long arm lift, HNT sye , herculined inside, bush wacker fender flares now geared and locked !!!
62 mm bored throttle body's fs - pm
skyway0018746 is offline   Reply With Quote
Unread 08-13-2014, 04:56 PM   #2
jakecarder
So how'd it happen? Not tight?
98 tj sahara, white, 4in skyjacker, 33s cragers, borla cat back, aem intake, stinger front, hi lift hood mount, mile marker winch, disco, b and m short throw, full amped audio, bikini top...totalled
05 tj rocky mountain, black, 2 in bb 31s, bank
00 xj marron, classic, stock dd
jakecarder is offline   Reply With Quote
Unread 08-13-2014, 05:39 PM   #3
skyway0018746
No idea ! Maybe the c clips popped off and it worked the cap off.
Unread 08-13-2014, 09:37 PM   #4
chris87xj
Jeepaholic
chris87xj's Avatar
1987 XJ Cherokee
^This sounds plausible and I hate it when that happens. Now I always double check to make sure the clips are fully seated.
***Chris***
JeepForum.com/IndyORV@Redbird-SRA
COTY 2009
Originally Posted by cruiser54 View Post
Better to hoard Jeep technical info than old newspapers and the neighbor's mail, I guess.......
Vote for the August Cherokee Of The Month here - Yes YOU!!!
chris87xj is offline   Reply With Quote
Unread 08-14-2014, 06:29 AM   #5
skyway0018746
Ive changed u-joints many times with out a problem . Dont know what happened. I used moog joints dont know if they have a flaw but I have spicer ones to replace them with .
Unread 08-14-2014, 06:57 AM   #6
Timo_90xj
Timo_90xj's Avatar
If you have alloy shafts, I strongly suggest running full circle clips. Stock-style c-clips can pop off and cause a u-joint failure. Literally all aftermarket alloy shafts are machined for the full circle clips, stock ones are not.
http://www.jeepforum.com/forum/f13/d...s-etc-1222317/
***Under construction***
Timo_90xj is offline   Reply With Quote
Unread 08-14-2014, 08:09 AM   #7
skyway0018746
Where do I get full circle clips ? My stub shafts are alloy and can take them now that you say that but my inner shafts are stock
