#1 | |
u bolt sizes?
I am installing a lift...rustys 3 inch full packs..no u bolts in kit. I asked advance for dana 35 u bolts and they said they need measurements? What size u bolts do I use?? I know I could have measured the axle but I was lazy and was hoping someone knew off the top of their head. Thanks
2001 Sport Silver 170,XXX 100 miles per day DD Rusty's 3 inch 30's PORC SYE 3 Inch Sway Links |
#2 |
I believe for the 35 you would use 2.75" x 9"
#3 |
Thanks..i will check that out..worse comes to worse I will just bring in the old ones and see if they have a match.
#4 |
I told advance that I think its a 2.75 x 9 and they told me it was too small for the cherokee, which makes me wonder how they know when they are asking ME for the measurements and I have told them?? Doesnt make sense, did some research and RE sells them 2.75 x 9 also so I think its right. I am just gonna pul one u bolt when I do the install and bring it down to advance..if no luck there I will try the dealership that is like 2 miles down the road, hopefuly they would have them, why couldn't I have ordered them from rustys!?
#5 |
Isn't there a decent spring shop near you? They would be able to make a set quickly, and know the correct size.
Say ya to the U.P., eh? |
#6 |
RE1225 U-Bolt Kit 3" x 9" (RE1225)
Set of four u-bolts and nuts for Cherokee, fits Chrsyler 8.25" rear axle. RE1220 U-Bolt Kit 2.75" x 9" (RE1220) Set of four u-bolts and nuts for Cherokee, fits factory Dana 35 and Dana 44 axles. |
#7 |
D35 = 2.62 inches
D44 = 2.75 inches 8.25 = 3 inches |
#8 |
I called rustys and they said dana 35 is 2 7/8 but 2 3/4 will fit its just tighter at the threaded end, you will have to pull it apart a little. Thanks guys
#9 |
The 2 3/4 inch u bolts were too big for the dana 35. I ended up reusing the old ones, once I get the right ones I will repalce them then. They are suppossed to be 2.62 inch like you said. Thanks
#10 |
I called Rustys to ask about the U bolts and they said that 2 3/4 is the right size?? I dunno, they said no matter what do not reuse the old u bolts, so I am just gonna put on the U bolts that I got from an off road center near my home. Something about the old ones being a lesser grade quality and they stretch over time and its better to just use the newer one even if they are not snug around the axle tube, there was about a centimeter of play. I hope it will be all right since I cannot find any smaller u bolts unless I get some stock lower quality u bolts from 4wd hardware.
#11 |
OLD tread revival but for good reason ^^
what sizes are the u bolts for the front Dana 30 and rear Dana 35. i know i need 8 total. .. but which of which do i get. .. im shoppin at this site since i want to order everything n include all shipping one basket. http://www.jeep4x4center.com/jeep-suspension-parts/wrangler-yj.htm
DFW Area Monthly JeepMeet! Next one June 4th! 1995 YJ 2.5 LOW OUTPUT 31s 4.5" Lift |
#12 |
Bump. ^^
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
