Types of 4x4 and how they work? - JeepForum.com
post #1 of 15 Old 03-06-2013, 12:10 PM Thread Starter
aldersonfilm
Everyone always take for granted that if you pull the lever in the center console, all 4 wheels start turning, but I'm curious if anyone knows the actual mechanics behind the different types of 4x4.
For example, I have Select-trac, so I've got 4-low, 4x4 part time and 4x4 full time. How do all of these differ? I'm especially curious about how 4x4 full time works.
aldersonfilm is offline
post #2 of 15 Old 03-06-2013, 02:17 PM
buildin1XJ
When I got my first XJ with selec-trac that confused me a little also. Part time position is meant to be used only when road conditions or off road conditions require the use of 4WD and are never to be used on dry paved roads. Full TIME 4 Hi can be used even on dry surfaces wet roads patchy snow covered and such because the front and rear axles are allowed to turn at different speeds and the owners manual actually states that full time can be used year round. 4 low is to be used when you need either more pulling power or decreased speed and is to never be used on dry pavement. When engaged in 4 low or Part time the front and rear wheels are turning at the same speed.
buildin1XJ is offline
post #3 of 15 Old 03-06-2013, 03:48 PM
Hudson
Part Time - T-Case doesn't compensate for inner wheel spinning faster when cornerning. Will bind up T-case if used on Dry pavement. Needs to be used on dirt or slippery surfaces so the wheels can slip.
Full Time - Opposite of Part-Time. T-case compensates for inner tire spinnning faster, and can be used on all sorts of surfaces. Can drive around all the time in 4 full time with no ill affects.
4 Low - Gears the Transfer case down into a really low "crawling gear". Gives WAY more torque and is better for offroading.
Live To Die. You're Not Going To Get Out Of This One Alive.
Build Thread - http://www.ausjeepoffroad.com/forum/showthread.php?t=121903
Hudson is offline
post #4 of 15 Old 03-06-2013, 04:43 PM
Kettles
Not exactly. The inner and outer wheel differentiating is done in the axle differential. In part-time the front and rear axles are locked together with no differential, therefore the average speed of the front axle and the rear axle must be the same. The problem with part time is that the rear axle and the front axle take different arcs in a corner (rear being smaller), so you get a binding similar to having a locker in an axle. The surface must be slippery enough to allow something to slip, so nothing breaks.
In full time there is a differential in the transfer case allowing the front axle and rear axle to travel at different speeds. The problem with full time is that like an open differential you can have 1 side spinning and the other stationary (in this case, the front or rear output are the "sides"). Now combine that with open differential in the axles you can get stuck with one wheel spinning like in 2wd. In part-time, at least one wheel on each axle have to be moving, so its harder to get stuck.
Edit: Fixed it up a bit when I got to a computer.
_=====o000o
//__l_l_,\____\,____
l_--\_l__l_/--|lllll|
_.(o)_)__.(o)_)--o-)_)
"Dee", a Patriot Blue 2001 Cherokee Sport 4.0L High-Output
"Live Free Or Die; Death Is Not The Worst of Evils." -General John Stark
Originally Posted by speedbucket View Post
perfect depends on how far away you are when you look at it:D
Originally Posted by Millermagic View Post
It's a 4.0 ... as long as there's something in the crank case that isn't coolant I'm sure it will still run forever.
Kettles is offline
post #5 of 15 Old 03-06-2013, 05:03 PM Thread Starter
aldersonfilm
Well explained Kettles! Thanks!
post #6 of 15 Old 03-06-2013, 05:36 PM
Kettles
Im at a computer now.
In summary
Full-time: differential action in the transfer case
Part-time: Locked differential in transfer case
4-low is just a part-time setting with a reduced gear ratio.
So if your off-roading, part-time is what you want to use. If your driving down the highway/street and your paranoid you might need more traction (or to help balance braking), full time is better. You can use full time, full time (as the name implies) if you want to, its effectively all-wheel drive. Generally the NP231 (command-trac transfer case) is more desirable due to significantly more aftermarket support. The NP242 (select-trac) I think hangs a tad lower.
_=====o000o
Kettles is offline
post #7 of 15 Old 03-06-2013, 10:26 PM Thread Starter
aldersonfilm
What about the older systems, like those in the CJ7s, with the locking hubs? Are you actually locking the front differential when you turn them?
post #8 of 15 Old 03-07-2013, 02:11 PM
biffgnar
biffgnar's Avatar
Nope, you're locking the hubs to the axle shafts. The diff is still open unless otherwise locked.
Romney in 2020!
biffgnar is offline
post #9 of 15 Old 03-07-2013, 04:23 PM
squirlgod
THANKS kettles for mentioning the fact that part time has more traction then full time...most people let that slip when they explain this, but its fundamental. More differentials=less traction.
"Yeah....It's Purple."
squirlgod is offline
post #10 of 15 Old 03-07-2013, 05:42 PM Thread Starter
aldersonfilm
Why didn't Jeep put locking diffs as stock? Land rovers had 'em.
post #11 of 15 Old 03-07-2013, 05:58 PM
biffgnar
biffgnar's Avatar
They did in Rubicon Wranglers
Romney in 2020!
biffgnar is offline
post #12 of 15 Old 03-07-2013, 06:21 PM
buildin1XJ
Your question is very simple Full time means you can run in that gear anytime you feel the need for extra traction. Part Time means when extreme weather or off road conditions exist. 4 Low for more pulling power and extreme conditions only. Never run your XJ in part time unless roads or off road conditions exist.
post #13 of 15 Old 03-07-2013, 06:23 PM
dmill89
1995 XJ Cherokee
A locker and the related hardware to make it work costs allot more than an open diff. See Below.
That being said I really wish that the lockers were offered a separate option on Wranglers (and the 4:1 reduction too). I wouldn't mind spending an extra $1,000-$1,500 or so for lockers (I doubt they'd cost Chrysler more than a couple hundred $ but I know there is plenty of mark up) and $500 or so for the lower transfer case ratio, but a Rubicon costs nearly $10,000 more than a base Wrangler sport for allot of options I really don't need/want.
dmill89 is offline
post #14 of 15 Old 03-07-2013, 06:35 PM
biffgnar
biffgnar's Avatar
Realistically the issue is that DC is running a business and most jeeps never go off road. They are already selling more than they can make as it is.
Along the lines of AWD v. Part Time and lockers, my old Lexus LX470 was AWD but had a locker in the TC (but diffs open).
Romney in 2020!
biffgnar is offline
post #15 of 15 Old 03-07-2013, 06:43 PM
buildin1XJ
Well you own a XJ and your only options are to buy lockers of your liking and a Atlas T case can give you more gear reduction. Other than that you can install an electrical system that will keep your rig from shifting into a higher gear when you need to stay in low T case and gear 1 on the transmission.
4x4 , full time , locking , selec trac , transfer case
