Two problems - JeepForum.com
post #1 of 18 Old 07-20-2013, 01:42 PM Thread Starter
cherokee jeepen
Two problems
My tail gate mechanism is not working, will not unlatch. Is there a way to remove the inner gate panel to access the mech with the gate closed? Or other suggestions?
My heater A/C fan only operates on high speed "4" on the switch, can this be fixed without replacing the whole $300 unit the dealer is telling me?
Thanks for your input
cherokee jeepen is offline
post #2 of 18 Old 07-20-2013, 01:51 PM
bpounds
bpounds's Avatar
My tailgate does that sometimes. I've always been able to open it by prying on the latch fingers with a screwdriver while pulling on the latch. Once it's open, take the latch apart and lube it up.
bpounds is offline
post #3 of 18 Old 07-20-2013, 06:49 PM
rocketboy
rocketboy's Avatar
I think if your fan only works on high, it means you need to replace a resister. I think if you ask at the auto parts store they'll know what you need.
rocketboy is offline
post #4 of 18 Old 07-20-2013, 07:06 PM
bigbossd1030
Not sure on the door, you will have to fiddle with it. As for the blower. It's called a blower motor resistor. It's like 7 bucks for a new one and takes no time to install. I might have a picture on my phone here... It's just above the vent on the passenger side.
Sent from my iPhone, probably because I am bored at work.
/l ,[____],
l----L-[]lllllll[]-
()_)-()_)--o)_)
OFFICIAL JEEPER
Any Jeepers in Edmonton, AB
I am on channel 33.
I live, I ride, I am JEEP.
bigbossd1030 is offline
post #5 of 18 Old 07-20-2013, 09:23 PM
Mark05059
you working on a jeep wrangler or a jeep cherokee... or something else?
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #6 of 18 Old 07-20-2013, 09:24 PM
bigbossd1030
Good call! I didn't even look at his name. Plus I can't see his info on my phone.
/l ,[____],
l----L-[]lllllll[]-
()_)-()_)--o)_)
OFFICIAL JEEPER
I am on channel 33.
post #7 of 18 Old 07-22-2013, 10:18 AM Thread Starter
cherokee jeepen
TWO problems
My jeep is a 99 cherokee
post #8 of 18 Old 07-22-2013, 10:19 AM Thread Starter
cherokee jeepen
My Jeep is a 99 Cherokee
post #9 of 18 Old 07-22-2013, 10:56 AM
jokerchief462
Since we have determined it is a Cherokee the fan speed is the resistor.
The rear latch mechanism I believe has a cover that can be removed. Has to be a way to get it open.
89YJ 2.5L TBI, AX-5, NP231 SYE, Ford 8.8, Yukon Grizzly, Tom Woods Shaft, 33" BFG T/As, 4" lift, Warn VR10000s.
AF Jeep Club Tail #184
jokerchief462 is offline
post #10 of 18 Old 07-22-2013, 11:13 AM
SeanB95YJ
might have better luck with responses on the XJ forum, this is the YJ forum... (XJ=Cherokee, YJ=87-95 Wranglers)
that said, I did have an XJ once - it was an 87 so yours may be different, but on mine, there was NO way to access the mechanism with the gate closed.
Good luck
Sean B. - Schenectady, NY - 95 YJ, 350/700r4/NP241, JB Shorty SYE, 8.8 rear, 2" BDS, 1" homebrew shackles, Daystar 1" BL, TJ flares, 35x12.50 General Grabber AT2 on 15x10 Bart D-Truckers, Polyshield polycarbonate windshield, HD over/under crossover steering
swap/build thread:
SeanB95YJ is offline
post #11 of 18 Old 07-22-2013, 11:20 AM
MoparMech
1995 XJ Cherokee
You need to ask yourself why the resistor went bad first tho. It would be a good idea to read the current draw of the blower motor and compare it to specifications. If it is way over spec. The blower motor is drawing too much current and taking out your blower motor resistor. I usually end up replacing both when I run into this problem.
MoparMech is offline
post #12 of 18 Old 07-22-2013, 10:35 PM Thread Starter
cherokee jeepen
Thanks folks, replaced the resistor ($54) and fan works well, all 4 speeds. Old resistor was rusted and covered in trash. Now all I need to do is solve the tail gate situation. I'm thinking I have to cut a hole in the interior panel
post #13 of 18 Old 07-23-2013, 07:19 AM
jokerchief462
Got to be a better way. Know anyone who steals cars??? Just a thought but with a picture if how the mechanism works you may get it open.
post #14 of 18 Old 07-23-2013, 02:31 PM
98muddyjeep
rockin lil red wagon
98muddyjeep's Avatar
You should be able to climb in the back cargo area and undo the screws and just pull off the panel giving you access to the inside latch mechanism with out destroying the panel,then jut the rod up a bit plenty of write up here if ya search a bit.
ah,beer the cause of and cure to all of lifes problems ...Homer J Simpson... I am the guy in the red jeep!
98muddyjeep is offline
post #15 of 18 Old 07-23-2013, 02:36 PM
Holder350
1995 XJ Cherokee
Pull up on the handle....HARD, and hit the gate above the handle with the palm of your hand. After you get it open pull the interior panel and readjust the linkage
Sent from my phone
95' XJ Country - Stock Skids - D30/D35 Limited Slip - 3" Lift - 31x10.50R15 - 4.0 HO - AX15 - NP231
98' XJ Classic - D30/C8.25 - 4.5" RC Lift - 33x12.50R15 - 4.0 HO - AW4 - NP231
Originally Posted by Azzy View Post
You can tell the character of a person in how they treat someone who can do nothing for them.
Holder350 is offline
