Turn signals not working............ - JeepForum.com
post #1 of 2 Old 05-26-2009, 09:23 PM Thread Starter
g26
so i did a search but couldn't find any previous posts. i have a 2000 XJ and just the other day i noticed my turn signals don't work. whether i signal left or right, the indicators on my dash don't work neither do the actual turn signal lights front and back. when i use the turn signal lever on my steering column for my high beams that works. so today i replaced my flasher relay under my dash and checked the fuse in the fuse box by the passenger kick panel and it looks good. what could it be? thanks.
g26 is offline
post #2 of 2 Old 05-26-2009, 09:37 PM
the_weirdo
the_weirdo's Avatar
It is possibly the turn signal lever. They do go bad after a while. Check out the FAQ section for a write-up. It is easy to change on 1997+ XJs.
the_weirdo is offline
front turn signals not working in 87 xj the87XJkid XJ Cherokee Technical Forum 1 08-16-2009 04:55 PM
turn signals not working cardana24 XJ Cherokee Technical Forum 4 10-09-2006 10:56 AM
Turn signals stopped working Jenniegirl XJ Cherokee Technical Forum 3 03-02-2006 07:00 PM
99 turn signals not working 46CJ2A XJ Cherokee Technical Forum 4 01-10-2005 02:36 PM
turn signals and hazards not working. puckjer XJ Cherokee Technical Forum 2 11-15-2004 04:22 PM
