turn signals not working - JeepForum.com
post #1 of 5 Old 10-08-2006, 08:09 PM Thread Starter
cardana24
Well I picked up my 85 xj this weekend. It has a 2.8 V6 and a five speed manual transmission. The problem is the turn signals are not working. When I went to get the jeep it was flooding in the area and the guy I bought it from told me he drove it in the flooded roads and the driver side floor board got wet...so I have been drying that out. The wierd thing is that the hazards work but none of the turn signals do. I do not hear the rymithic ticking you normally hear with a turn signal when its on, and the lights on the dash to not light up to indicate which way you are turning. The fuse box got wet when the guy drove it thru water so I figured it may be the flasher...so I replaced that but that area was still wet when I did, and I still get nothing. What gives? Does any one have experience with this? I need to get this inspected so I can get it on the road.
** I was drying the fuse box out with a hair dryer tonight, to try to eliminate that.
cardana24 is offline
post #2 of 5 Old 10-09-2006, 07:28 AM Thread Starter
cardana24
any help on this? Should I start out by checking all the bulbs? Would a burnt out bulb cause this problem? Thanks for any help.
post #3 of 5 Old 10-09-2006, 10:18 AM
olds442
olds442's Avatar
yes i would let everything dry out, change the flasher fuse, and then replace the bulbs if nothin works after
Family Wheelin...
Dad- '08 JK Rubicon- Stock, BB and 33s coming
Sister- '07 FJ Cruiser- Rear locker, BFG A/Ts
VT
olds442 is offline
post #4 of 5 Old 10-09-2006, 10:50 AM Thread Starter
cardana24
you think I should change the flasher again? I have already done it once, but when I plugged the new one in the socket was wet. Do these things fry easy?
post #5 of 5 Old 10-09-2006, 10:56 AM
olds442
olds442's Avatar
yes, i would def try a new one, but let it dry out first
Family Wheelin...
VT
olds442 is offline
front turn signals not working in 87 xj the87XJkid XJ Cherokee Technical Forum 1 08-16-2009 04:55 PM
Turn signals not working............ g26 XJ Cherokee Technical Forum 1 05-26-2009 09:37 PM
Turn signals stopped working Jenniegirl XJ Cherokee Technical Forum 3 03-02-2006 07:00 PM
99 turn signals not working 46CJ2A XJ Cherokee Technical Forum 4 01-10-2005 02:36 PM
turn signals and hazards not working. puckjer XJ Cherokee Technical Forum 2 11-15-2004 04:22 PM
