Turn Signals, Hazards, Break Lights, High Beams - JeepForum.com
post #1 of 10 Old 05-23-2010, 09:29 AM Thread Starter
ChadsXJ
1995 XJ Cherokee
Ok just a little history in case it matters, my 95 xj sport sat for about a year, had the radio stolen, dead battery and seized alternator. I replaced the alternator and charged the battery to drive to a new house and jeep started and ran fine.
On the way, I noticed I had no turn signals or break lights. parked it at the new house and I am now working on it to get it to be a DD. I have discovered that I also have no hazards or high beam headlights. I do have low beams and tail lights. All bulbs are good.
The stolen radio was disconnected at the connector, no cut wires there.
I replaced the dual flasher under the steering wheel (square relay), new battery, new multi-function switch and new brake switch.
I cleaned the ground by the battery on the fender well and the ground that attaches to the block behind the alternator.
I checked all the fuses in the PDC and all visually are ok.
The fuse box under the dash is where I see one problem and don't know how to fix it. The fuse slot for the turn signals (#8) is missing one of the 2 female connectors, so I have a feeling that is part of the problem.
I have a multi-meter, and only have a 1 mA draw, not sure what to check next.
PLEASE HELP!
ChadsXJ is offline
post #2 of 10 Old 05-23-2010, 04:17 PM Thread Starter
ChadsXJ
1995 XJ Cherokee
started with headlight high beam problem, no high beam power at bulb. started to trace back and opened connector behind driver side headlight. all kinds of corrosion and some pins stayed in when I opened it.
Is there any harm in just cutting the "connectors" off and splicing the ends together? or do they sell a kit to replace just the connectors?
ChadsXJ is offline
post #3 of 10 Old 05-25-2010, 06:32 AM Thread Starter
ChadsXJ
1995 XJ Cherokee
Well, I cut the wires on either side of the connector and spliced the proper ones together. Now my high and low beams are working as well as the parking lights which have never worked. Still no turn signals, hazards or brake lights.
Next step is to trace out stop light wires...currently no power for stop light circuit at connector behind spare
Tail lights and backup lights working.
ChadsXJ is offline
post #4 of 10 Old 06-03-2010, 09:25 PM Thread Starter
ChadsXJ
1995 XJ Cherokee
I am adding to this thread since its all the same troubleshooting...
I found a corroded wire for the hazard circuit at the engine side of the bulkhead connector. Where can I get the small terminal/connector to replace the corroded one? I'm assuming it will just "pop" out of the big connector....
Also, should I clean out the bulk head connector or is the black gunk supposed to be in there? dielectric grease?
ChadsXJ is offline
post #5 of 10 Old 06-07-2010, 05:43 PM Thread Starter
ChadsXJ
1995 XJ Cherokee
In case some one has similar problem, the larger pins in the bulkhead are metri-pack 480's, the smaller ones (which is what the hazard circuit is on) are metri-pack 280's. I found mine at Napa
I pulled lightly on the wire and it came right off of the bulkhead. Since the wire wasn't attached anymore, I pulled the pin out from the pin end. I stripped the corrosion off of the old wire, and attached it to the new pin. I had to grind down the new pin a little bit to get it to go back in the bulkhead. I cleaned the bulkhead with contact cleaner, covered it with di-electric grease, and put it back together. Hazards, turn signals and brake lights all now work.
I found a FSM for my year and this definitely helped with detecting the bad wire, I recommend getting one.
ChadsXJ is offline
post #6 of 10 Old 03-18-2014, 08:50 PM
96CherokeeS
Thank you!!!!
I'm currently trying to troubleshoot this issue. Thank you for your continued updates!
96CherokeeS is offline
post #7 of 10 Old 03-19-2014, 06:46 AM Thread Starter
ChadsXJ
1995 XJ Cherokee
Glad someone found it usefull.
1995 White XJ 2-Door Sport 145K miles
4.0 6L, 4.5" RC full leaf pack, coils, and fixed length LCAs, IRO Rear BPEs, Front YJ Brakelines, IRO HnT SYE with Front DS, Cragar Blk D-Window 15x8 4"bs, General Grabber AT2s 33x12.50, Rear Hitch with Warn D-Ring Shackle, Dynomax Super Turbo, HD Offroad Shackle Relocation brackets, IRO Front Hooks, Fenders Trimmed, Stock Flares relocated, floor pans replaced.
ChadsXJ is offline
post #8 of 10 Old 03-19-2014, 08:49 AM
96CherokeeS
By chance, have you ever experienced any issues with your aux radiator fan? I raplaced the fan and the relay and checked all of my fuses. Checked power to the wiring harness that attaches to the fan wiring harness and its doesn't have power... does this model have a solid state? If so where is it?
post #9 of 10 Old 03-19-2014, 02:52 PM
rick_rob
Check the grounds behind the back side panels.(behind spare tire). If I remember right there are 3 one the driver side. When I had problems with my taillights it was the grounds in the back. But my problem was I would hit the brakes and the front parking lights would turn on.
rick_rob is offline
post #10 of 10 Old 03-19-2014, 06:25 PM
JWELK
Very thorough troubleshooting and write ups.
Thank you
Jim W
JWELK is offline
brake lights , electrical , fuse block , turn signal
Turn Signal Signals on Hazards sometimes.. Mikedorr86 XJ Cherokee Technical Forum 8 10-21-2008 02:47 PM
Electrical nightmare. ....turn signals, hazards, etc. HELP! 4.0H.O.XJ XJ Cherokee Technical Forum 8 02-20-2008 12:10 PM
Messed up hazards/turn signals/dashlights....WTF?!?!? 4.0H.O.XJ XJ Cherokee Technical Forum 1 02-19-2008 02:32 PM
Headlights, turn signals and hazards 3fifty XJ Cherokee Technical Forum 2 10-23-2007 12:07 PM
turn signals and hazards not working. puckjer XJ Cherokee Technical Forum 2 11-15-2004 04:22 PM
